Results 1 to 10 of 11
Thread: Bevel Gear Cutting
    Jul 2010
    Default Bevel Gear Cutting
    Can anyone guide me to an article(s) showing how to design and cut plain bevel gears. BEN
    Mar 2003
    LAS CRUCES NM
    Default Start here.
    Quote Originally Posted by beni73005
    download the google "Brown & Sharp's"; "Practical treatise on gearing"; PDF.
    http://www.archive.org/details/practicaltreati00rigoog
    read some, (chapters ix & x), ask more questions,
    Les H.
    The Impossible Takes Just A Little Bit Longer!
    Vancouver's Island
    Vancouver's Island
    Maine
    Get Ivan Law's book "Gears and Gear Cutting." It's available from here http://www.lathes.co.uk/books.htm if you can't find a local source.
    Kozo Hiroka (sp?) also describes the process in at least one of his locomotive construction books.
    Western New York U.$.A
    I know this ain't what you asked but I'll shove it out there anyway as it may help some.
    Tractor Service Supply has this type of gear in stock as farmers use them alot. Depending on your needs, they might serve you well.
    http://www.tractorsupply.com/
    Apr 2006
    Banbury England
    Default Bevel Gear Info
    There are two major ways of cutting bevel gears to the amature with a milling machine.
    The standard type bevel gear where, the pitch diameter, the top of the tooth (addendum) and the bottom of the tooth (dedendum all point to the same centre. As per the drawing posted earlier. This means the tooth is tapered in two directions and requires the use of BEVEL gear cutters of the Brown & Sharp pattern. After cutting the inner face needs fitting by filing.
    The Pentz Parallel Depth Gear is different in that the pitch diameter is the same as in the above but the addendum and dedendum are to tapered to the same centre as the pitch line but barrel to it. this means that gears can be cut that run without fitting and use standard gear cutters.
    The best explanation of this I have seen is in American Machinist gear Book which can be viewed here. http://www.archive.org/stream/americ.../n148/mode/1up Page 131 shows a section of the standard bevel gears and P144 shows the parallel form.
    Steve Larner
    Jul 2010
    Sure do thank all the guys who wrote on this thread to help me learn more about bevel gears and how they are cut. BEN
    Quote Originally Posted by SDL
    Interesting... I seem to have re-invented the Pentz type..... I cut some gears on that principle a while back, and even made a fixture for it....
    My copy of the Gear Book does not have that section, although it does cover bevel gears.
    Jul 2010
    J. Tiers:
    Would you happen to have a picture or sketch of your "fixture" for cutting the bevel gears that you could share with us here?
    Thanks. BEN
