Results 1 to 10 of 10
Thread: What insert does this indexable mill takes?
Hybrid View
    Nov 2009
    San Francisco, CA
    Default What insert does this indexable mill takes?
    Dec 2004
    where the Snake swallows the Salmon
    You haven't given us a lot to go on, but it looks like the same triangular insert used on cheap lathe turning tools.
    Feb 2010
    One picture looks like the insert is set at an angle to give it rake. One picture it looks like it is straight in there.
    If it is straight (Not angled to give it some rake), It is probably a TPU or TPG 3XX or 4XX (Judging by size, I am guessing it is most likely a 3XX series)
    Dec 2007
    Richmond BC, Canuckistan
    It's most likely TNMG3xx or TNMG4xx.
    There's a good chart here:
    http://www.carbidedepot.com/formulas-insert-d.htm
    That will let you figure out what numbers to put in the x...
    Chris
    Aug 2006
    Beaverton, OR
    Ill say TNMG as well. Probably the most common insert out there.
    Oct 2006
    Ivins, Ut
    Actually, the circle measurement is whatever will fit WITHIN the confines of the sides of the triangle. The points are outside the circle.
    gnm109 Guest
    Quote Originally Posted by morehelium
    Chris
    Yes, I think it's a TNMG but I can't tell the I.C. from the picture. I use those on a few indexable holders. Thet need some rake as shown as the edges are square. They cut rather when well when properly oriented.....
  8. #8
    To be sure call Rouse but it looks like a TNMG33X. Find a piece of 3/8" diameter stock (washer or a slug) & put it on the insert if it touches all 3 sides it's a 3/8" IC (inscribed circle), if the slug is too small do the same with a 1/2" diameter & if that fits it's a 43X. The thickness for either is .187" or 3/16" & the tnr (tool nose radius) can be checked on a comparator or with a radius gage. A 1 is a 1/64", a 2 is a 1/32 & 3 is a 3/64", etc.
  9. #9
    Jun 2004
    N.J.
    Did you check their website? http://www.arno-rouse.com/us/products/milling.html What is marked on the side of the insert?
  10. #10
    May 2007
    Live Oak, TEXAS
    Start with a "TNMT"_ _ _ _
    You need to measure the thickness, and how big of "circle" the 3 points of the triangle would make.
    Is it solid, or does it have a hole thru it?
    You can figure it out pretty easily at this link:
    CARBIDE SIZING
