Results 1 to 10 of 13
Thread: Box turning tool ???
    Sep 2004
    Oregon Coast
    Default Box turning tool ???
    A friend gave me small box full of lathe toolbits a while back. Today I was cleaning out a drawer and uncovered them. There a half dozen bits that are marked "Micro 100 BT- 4 thru 7. I spent a little time looking on the web and then the KBCTools catalog and could only come up with a name, nothing on How to use them. Can any one tell me any thing about them. Which side is up or how they are used?
    Thanks Mel
    Mel Larsen
    Dec 2003
    Palo Alto, California
    A box turning tool is typically used on a turret lathe, and it holds a stubby lathe tool along with appropriate follow rollers to keep things on track.
    Here's a dark image from Wikipedia:
    Frank Ford
    HomeShopTech
    Jul 2001
    Green Bay, WI
    The tool bit maybe used in a vertical position, so do not consider it as a normal Lathe tool would approach the work piece
    Nov 1999
    SE OZ
    Feb 2007
    Sonora Calif.
    Default box tool
    End of tool is the cutting part point of v is cutting edge and v is where chip curls out. Pic is out of W&S turret lathe book and does not show that deep of
    chip breaker.
    Jim
    Sep 2004
    Oregon Coast
    Thanks for the information guys. Looks like I will have no need for them. I was hoping to find a way to use them.. If any one has a use for them send me a PM and I'll send them to ya. There are 2 of the #8 and 6 of the #6's four of them still have the wax protector tips on them.
    Thanks again
    Mel Larsen
    oldbikerdude37 Guest
    Quote Originally Posted by Frank Ford
    yes box tools can turn long thin parts. think of it as a turning tool on a Tailstock (endworking tool) with a built on follower rest. thats what a box tool is.
    lugnut,
    You might consider making the box tool to utilize them. Look at www.downrivertools.com. I'm just starting one from his drawings and a couple of the balance tools.
    Sep 2004
    Oregon Coast
    Default They headed for CA
    I just sent the tools to Jim. Thanks for all the replys and help.
    Mel Larsen
    Scotland.
    They are called tangential turning tools.They can be used on centre lathes and others if you make a holder.
    Mark.
