Results 1 to 10 of 11
Thread: What's this Hardinge thingy called?
    Default What's this Hardinge thingy called?
    I know that this is a 5C collet indexer, and it has Hardinge D-365 on it. But what is it called, and how much is it worth? I'm buying it, not selling it.
    Aug 2005
    shreveport La
    Smile
    That is a dividing head. A chuck will screw on the threated nose and collets can be used in the tapered bore . If you got all 3 plates and the tail stock . around her a couple of hundred dollars. I hace seen them go for as little a $100.00 to around $500.00.
    Oct 2004
    Prestatyn, North-Wales
    its a dividing head .. also i think, it takes a hardinge chuck.
    all the best.markj
    It's got a 3 jaw chuck, but I don't see a name on it. There are also about 6 different indexing plates, and another 2 that would need the center hole bored out to make them fit.
    Apr 2007
    Fairport NY
    Default ...it's bound to take your life there's a bathroom on the right...
    It is wothless, and in fact many MANY people are killed or horribly maimed by these devices.
    I run a disposal service. Send me the device, all the plates and accessories and I will prevent it from injuring or maiming you or your family.
    Foxtrot-Lima-Bravo Machinery Recycling
    120 Bongo-Bongo Street
    Ripnoff, Rode Island
    C/O Liger Zero
    Plastic Operators Dot Com
    Quote Originally Posted by Liger Zero
    C/O Liger Zero
    Thanks for your concern, I'll put it in the mail, first thing yesterday.
    Sturgeon Bay, WISCONSIN (near Green Bay)
    If the insides are in good working order, make sure you paint it up real purty. It'll be your new log/record of how often you use it.
    John M...your (un)usual basement dweller
    Sep 2002
    Dayton, Ohio
    If the chuck and jaws are in good shape, $500 would be about my top dollar for this. They also made them with a taper nose, and I think those are a little more desireable (maybe not). Down in the $350 range, and I think you're doing real good. Any lower, and you'll be required to post a "tool gloat" thread.
    Buffalo NY
    Chuck mount should be 2-3/16"-10.
    Ratio is 4:1.
    I think 3phaseLightBulb has a manual for it on his site.
    --Doozer
    Thanks for all the info. Can anyone tell me what the recessed male 5/16" hex that is on the upper left in the photo is for. It only seems to move about 1/16th of a turn and I don't want to force it into the wrong position.
