Results 1 to 10 of 31
Thread: Looking for schrader fittings (female)
    Jul 2009
    SF bay area, CA
    Default Looking for schrader fittings (female)
    I am looking for female schrader fittings which screw onto a schrader valve on one end, and have some kind of a fitting on the other... I guess any kind is ok except for crimp on. I am failing to find these, although they exist on shock pumps for bicycles.
    Sep 2002
    Dayton, Ohio
    You might look inot aircraft supply locations
    Aug 2003
    Southwest Georgia, USA
    The only place I've seen those is on a bicycle tire pump. So, here's where you can get one:
    http://www.diamondu.com/accessories.htm
    It's their 9001 or 9002 depending on the barb size, about 2/3 way down the page.
    Feb 2005
    mcmastercarr.com
    Jul 2009
    SF bay area, CA
    Quote Originally Posted by ahidley
    mcmastercarr.com
    What's the part number?
    Jun 2003
    Columbus, Ohio
    Automotive stores have a conversion fitting for fuel mechanics pressure gages. They have one size that will fit a Schrader valve that you would find on a tire and has larger threads on the other end for a gage. I have one that cam with a kit from Actron out of Cleveland.
    I'll see if I can find a link.
    Otherwise, you might be better off to make one.
    rock~
    Jun 2003
    Columbus, Ohio
    Ok, here is some info. Kit number CP7818 gets you everything in the photo below. Its called the Ford fuel line adapter. You want the little brass part shown separate here.
    Call customer service and tell them you lost that part and see what they want for it.
    Customer Service
    For product information or customer service
    please call 1-800-ACTRON-7 (1-800-228-7667)
    Monday through Friday, between 8:30 a.m. and
    4:30 p.m. Eastern time or fax anytime at
    (216) 651-2388.
    Actron can also be reached by Email or on the
    Internet.
    Email address: sunpro@actron.com
    Internet home page: http://www.actron.com
    Here is the pdf where that info came from.
    Actron pressure gage kit
    And, just because I had to buy one today, you can get a part with a Schrader valve on one end and a 1/8 npt on the other end at Lowes in the well pump section for about $3.00. Not that it had anything to do with your post, but just cause I found one.
    rock~
    Feb 2009
    West of Sconniewood
    Is this what you are looking for? http://www.thefind.com/garden/info-schrader-couplers
    Sep 2002
    Dayton, Ohio
    Jim,
    The spruce link is for aircraft struts, it does not have the little button in middle to depress the little schrader valve inside he stem. I have one of those, handy for some stuff, worthless for airing tires and such.
