Anyone tried making one of these? http://www.subtleenergies.com/ormus/...ch/Vortrap.htm
100PSI air in, -50Celcius and 200Celcius air out [aprox].
Edit: this seems like a bad idea as it consumes too much air - I don't think my rotary vane pump can handle it at all. Commercial models run as low as 2 cfm, but with 100psi minimum (my pump is 10cfm, 10psi). A better alternative that HSM'ers have concluded - for non-ferrous metals - would be to use ethanol mist. It's 15$ for 4L, but you're using it as mist ...
