Results 1 to 7 of 7
Thread: Forming Acetal gears.
    Apr 2009
    Default Forming Acetal gears.
    Some weeks ago I showed how I had heat formed some lightweight ABS gears and Evan tried the same with Acetal. If I recall correctly, Evan tried heating the blank but the forming failed.
    Now that I have some black plastic which is probably not Acetal but I tried it anyway. It is much harder than the ABS was and there was no sign of it forming without added head.
    This time I put the blank on an arbor in the chuck and mounted the steel gear on the tool post, I pressed the gear against the rotating blank which started the familiar rumbling sound then I put my heat gun to the edge of the gear and when the rumbling eased I advanced the feed and repeated until the teeth were formed at full depth. Success!
    Well formed teeth that appear to be full strength but I can not get rid of the hairy edges!
    Oct 2009
    Louisville, KY
    Load the 'hairy' gear with grease and proclaim victory.
    So, would that be hobbing or forming?
    Canada, Bc
    Yea, Call the hairs 'Oil wicking surface' or something
    Nice job.
    Apr 2009
    Yes, obviously the technique needs a bit more development!
    Dec 2008
    Kendal, On
    Quote Originally Posted by dp
    fobbing, or horming
    Would the hairy gears and unusual technique make this guerilla or gorilla machining then?
