Originally Posted by
aviatakl
To the collective.
I have an 'old' CZ300C lathe made in the ROC. The 3 jaw chuck is worn out, I have owned this lathe for 12 years and it has done a fair bit of work.
I have acquired a new 3 jaw chuck that was removed from a new machine due to a slight 'run 'out'.
OK I figured that I could true the chuck by grinding the jaws.
The run out is in the order of 0.18mm. It was 0.26 when I stated.
Is grinding the jaws the way to correct this? I have a flexi drive dremel type tool and it does a good job, positioned on centre in the tool post.
Any advise is welcome.
Jim O'Donnell
New Zealand
You'll get more learned, detailed answers here but you're on the right path. I'm assuming the flexi drive can be rigid mounted? Key word Flexi here.
Make sure to cover your bed ways to keep all the grinding dust off of everything.
Dan from Raleigh, NC
If it's stupid but it works, it's not stupid.
_____________________
"What is your host's purpose for the party? Surely not for you to enjoy yourself; if that were their sole purpose, they'd have sent champagne and women over to your place by taxi." P.J. O'Rourke
