Random thing iv noticed: While venting the actylene tank, the output pressure of the regulator goes *up* as the input pressure goes down.
Result? If you had it at 10psi, it might go over 15psi before the tank is emptyed. Allways insure your acetylene regulator is set 'low' (5psi or less) before venting!
