Page 1 of 6 123 ... LastLast
Results 1 to 10 of 52
Thread: Anerobic adhesives
    Jan 2002
    Huntsville Ala
    Default Anerobic adhesives
    Do anerobic adhesives such as Loctite work in wood, or other porous materials? e.g. permanently fixing a bolt or screw in wood?
    Or would epoxy be a better choice?
    52N 122W Western Kanuckistan
    No, they will not work. Oxygen isn't the only problem. The resins in wood inactivate many of the cyano adhesives so they must be formulated for wood. Epoxy is the best choice.
    Jan 2002
    Huntsville Ala
    Drat! I was afraid of that.
    Thanks Evan.
    MuellerNick Guest
    WHAT Loctite? The ones for metal do not work.
    But CA ("super glue") works great on wood. Ask a model builder ...
    Sometimes they don't want to react, then use zipper (an activator).
    Nick
    There are many types of cyanoacrylates. Some work with wood and some don't. Loctite thread lockers are based on cyanoacrylates too but definitely don't work with wood. One way to make most cyanoacrylates polymerize instantly is to prime the surface with sodium bicarbonate powder. It can also be used to build up a fillet of dry powder which you then soak with very low viscosity CA glue such as ZAP.
    Warning: If you use the sodium bicarbonate trick the glue will go off IMMEDIATELY. It will release a considerable amount of noxious fumes so be sure to have the airflow away from your face.
    MuellerNick Guest
    I think I wrote that it doesn't work with thread lockers (= for metals). But they are not CA-glues.
    I also think I wrote "super clue", and that clearly works with wood. What is commonly called CA reacts with water.
    Loctite for metal is an modified anaerobic glue that needs metal to cure.
    But you only had to contradict ...
    Nick
    Not contradicting, correcting.
    Superglue is a Brand, not a specific glue.
    Cyanoacrylate glues are catalysed by bases, not water. Most surfaces tend to be basic and water mobilizes those ions. Why don't you try it instead of shooting off your mouth? Woods are usually acidic and prevent catalysis.
    Loctite is also a brand, not a specific product. The Loctite thread locking compounds are based on a modified cyanoacrylate formula, usually polyglycol methacrylate. Metal is not the catalyst. Oxygen acts as an inhibitor for thread lockers. When they are out of contact with oxygen the reaction is able to proceed.
    So far you are batting zero. Care to make any other mistakes today?
    Nov 2009
    Ontario
    Why do you have to be like that?
    If you buy crap, be prepared to re-design and fix it.
    MuellerNick Guest
    IDIOT!
    I wrote CA ("super glue") I wrote both the brand an the common denominator. Now you ASSHOLE FROM OUTER SPACE have nothing more to do than just pick out what suits your three rotten neural cells to start just another useless discussion.
    YOU ARE SO DUMB THAT IT HURTS!
    CA stands for methyl 2-cyanoacrylate, ethyl-2-cyanoacrylate, n-butyl cyanoacrylate, 2-octyl cyanoacrylate. CYANOxxx! Not methylxxx. The C in CA! methacrylate lacks the CN (= cyan)
    PISS OFF AND ADJUST YOUR FILTER!
    Nick
    Netherlands
    Well, this is just not true, otherwise it would solidify in the bottle. It needs the metal AND the lack of oxygen.
    Directly from the site of Permabond:
    "By definition, anaerobic adhesives remain liquid until isolated from oxygen in the presence of metal ions, such as iron or copper."
    Igor
