Page 3 of 11 FirstFirst 12345 ... LastLast
Results 21 to 30 of 104
Thread: willson slant bed lathe
  1. #21
    Scotland.
    I posted this in your other thread so thought I would copy it here.
    You can buy blank gears from HPC.If you`re replacing a gear with a splined bore.Turn the old gear down and use what`s left as a bush for the new gear.
    You can make gears on the mill quite easily with an involute cutter and your dividing head.
    Or you could ask John Stevenson to cut one for you or just for advice.John knows his gears and loads of different ways to do them.
    Looking at the picture you only seem to need three gears,or is there more welded than the one I can see?
    Edit:Now I seen this pic I think you need more than three gears.
  2. #22
    Aug 2010
    galston Scotland
    stript out gearbox off of lathe today.
    managed to cut welded gear from shaft with some carefull angle grinding!
    knocked out taperer pins from gears and it all came to bits quite easily.
    drive gear has no teeth left but i can still count how many were on it, but idler gear is missing ! how do i work out what size it is and how many teeth
    if i measure the shaft centres could i work it out from there?
    i'll post some pictures of gears etc soon.
    regards
    Tom...
  3. #23
    Nottingham, England
    Take a couple of the cluster gears at random and count the teeth then measure the OD and post these.
    This will allow us to work out what size tooth we are looking at.
    Then count how many teeth the drive gear should have. I'm presuming the drive gear is the one in the idler bracket [ more pictures needed ] ?
    If so then work out the centres of the bottom shaft to the centre of the missing gear and post that.
    If the drive gear is stripped double check all the cluster gears for damage, something must have ripped the teeth off.
  4. #24
    Scotland.
    Quote Originally Posted by John Stevenson
    I had one where some one had stripped the saddle apron at one time and rebuilt it without the interlock to stop the feed and leadscrew being engaged at the same time.Made a right mess of the qc box.
  5. #25
    Aug 2010
    galston Scotland
    also found out today that the 4 jaw chuck that came with lathe does not fit
    it looks the same but has a smaller taper and thread than the face plate, any one want a swap
    seriously though, how do i know what spindle size my lathe has it says american short taper Lo http://www.lathes.co.uk/willson/index.html but is that not the smallest size??
    thanks for the help.
    Tom.
  6. #26
    Aug 2011
    Central Virginia, USA
    Quote Originally Posted by scotplant
    Tom.
    There is an L00
    allan
  7. #27
    Nottingham, England
    Measure it.
    http://www.lathes.co.uk/latheparts/page12.html
    Then advertise for a swap on
    http://www.homeworkshop.org.uk
    It's a completely free site, no fee's from either end, very popular in the UK.
  8. #28
    Scotland.
    Smile
    n
    Is Scotland not in the UK then?
  9. #29
    Feb 2008
    Quote Originally Posted by Mark McGrath
    Not for much longer if Mr Salmond get's his own way
  10. #30
    Nottingham, England
    Not in my book, anywhere you have to have your money changed and passport stamped, Watford Gap, Hereford or Carlisle is going abroad.
    Just like Neil Armstrong was the first American to venture abroad.
