I bought a couple of used AC servos to convert my bridgeport. I installed the Demo of Mach3 and hooked it up to the breakout board that is connected to my servos. Right now I only have one motor hooked up.
How can I test the servo thru Mach3 ? Do I just run a program and Mach3 should pulse the X axis ?
I am reading the manuals but no luck yet. I was hoping for an easy command in Mach3 like JOG x-axis back and forth ???
Any thoughts ?
Thanks,
Kevin
