Nope. Skateboard bearings ain't gonna do it. A Dumore, properly set up, has NO discernable vibration. Zip. Nada. Nil. That's why Dumore parts cost so much. That's why you need good bearings. Otherwise you'll get chatter marks on the finished surface, and it doesn't take much vibration, at all, to get chatter marks.
That's also why you need balanced pulleys. If you do make 'em, if you drill a setscrew hole HERE, be sure to put one THERE, opposite, to maintain balance. Even that may not be good enough, but at least do that.
