Results 1 to 8 of 8
Thread: Bridgeport `way wiper` felt guard
    Dec 2010
    Folkestone
    Default Bridgeport `way wiper` felt guard
    Hi
    I have recently purchased a S1 bridgeport milling machine which required a little work, it is my first `upgrade` from the Warco all in one, but I need some info/advice if possible?
    Basically I am trying to get hold of some ready cut felt guards that are attached to the table and sweep the ways clear of swarf and prevents it entering the mechanism.....I have found them in american catalogues but am struggling over here, admittidly i have been lazy and just relied on the internet searches...
    Would anyone know where I can get these? I could just make them out of gasket paper but would prefer the pre cut OE type.
    Many thanks.
    Beaverton, OR
    I personally dont like felt wipers. They catch grit. I replaced mine with these:
    http://www.kabelschlepp.com/waywipers.htm
    Work real good and keep the ways very clean.
    Oct 2004
    Prestatyn, North-Wales
    I used piano "Check Felt" from here :-
    http://www.fletcher-newman.co.uk/frameset.html
    the peice i got from them is enough for a lifetime , will do the bridgeport and my lathes several times over .
    1 metre long by 100mmm wide 4mm thick
    cant remember what it cost though ..but think it was under £20
    all the best.markj
    Woodinville, WA
    I just buy F2 felt from McMaster and cut my own.
    Sep 2008
    WI/IL border
    I bought a set either on eBay or at http://www.machinerypartsdepot.com/.
    Jul 2001
    Green Bay, WI
    Gtrack
    Are you in Kent England, or Georgia USA ?
    Makes a difference
    Dec 2010
    Folkestone
    Many thanks for responses, i`ll try and get a set but thinking about it could be just as easy and more economical to make a couple sets.....depends on cost, as usual, i guess.
    Folkestone, Kent, England......
    Cheers
    gnm109 Guest
    Quote Originally Posted by macona
    Yeah, felt is a swarf collector. There's no way to get the chips out of them. On my Webb Mill, they use molded rubber wipers that are similar in concept to the ones in your link here.
