Originally Posted by
becksmachine
When holding a tap in a Jacobs chuck, I always used the "spin factor" as a poor man torque limiter. Now, this is using a ball bearing style Jacobs chuck, tightened about as hard as I can twist the key.
It seemed to work out about right that when the tap starts spinning in the chuck, I am doing something wrong; pushing too hard, not pushing hard enough, flutes packed full, dull tap, hole too small etc.
If I really need to twist the tap harder for 1 or 2 holes, I will start the tap with the chuck to establish alignment and then finish with a tap wrench.
Dave
I agree, but what do I know?
When the tap slips in the chuck, hand turning the chuck in neutral, I know it's time to back out, clean out the chips and go in again with the tap handle.
Thanks Dave for articulating this. If my chuck grabbed the tap hard enough, it might break. New problem.
If you buy crap, be prepared to re-design and fix it.
