Can 304 stainless be welded with an oxy-acetylene torch?
No you can't weld it that way.
Plain ol Bill
Check this out - http://www.hobartwelders.com/weldtal...p/t-39593.html
Yes, it is weldable with an O/A torch. Use the proper flux and TIG filler rod. If not near a welding supply, Tinman sells this flux for stainless. His products are excellent and reasonably priced.
https://www.tinmantech.com/html/stai...ing_suppli.php
He brushed the bead, which means he probably sugared (overheated) it, and it came out flat grey (not good!). That's why welding inspectors insist on seeing the weld before you brush it -- you must have the rainbow oxides which show that you didn't cook it.Originally Posted by Hogridnfool
It takes some practice. This is 10 gage 304 stainless with TIG:
Lap joint, same material/thickness. Colors are a bit washed-out by the flash, but you get the idea:
HERE is a copy of Chapter 18 from the Linde Oxy-Acetylene Handbook that was referenced in the linked thread.
I see you didn't get the heat shield in you kit either.Originally Posted by oldtiffie
I asked about the heat shield but they didn't have any in stock and advised me to make one a save a few dollars - which I did.
They provide very good support here in OZ.
Its a good kit. I use mine instead of my standard O/A kit and it saved me buying a TIG set and so saved me floor space and another rental bottle (for TIG).
Nice kit, what are the trigger looking things on the handle for?
