Results 1 to 7 of 7
Thread: keep it simple cnc question
    Oct 2004
    Default keep it simple cnc question
    There's someone here that use. Keep it simple cnc from Jeff Roak
    Beaverton, OR
    Its crap. I used it.
    Makes up all circular and helical moves from a zillion tiny moves instead of G02 and G03 moves. This gets you incredibly slow moves.
    Plus the same functionality is built in the wizards of Mach3 so what's the point? If I am going to spend the money I will buy the Newfangledsolutions conversational pack.
    May 2010
    East Central IL
    Macona is right. Go with Mach 3. While it is a fairly sophisticated program in functionality, it is easy to use. Set up may be time consuming for the novice or with particular machine set ups. The end game though is a very robust controller that can do a lot.
    The NewFangledSolutions Wizards are great to work with. Although I've merely scratched the surface, I find them to be pretty easy to work with. Plus they're somewhat intuitive.
    Hope this helps,
    Terry
    There's only one way to find out, might as well get started now!
    Beaverton, OR
    SimpleCNC isnt even a controller. It is just a stand alone program to make crap code.
    Oct 2004
    The object of my question is that. I can t use it at all. Only get script errors.
    Nottingham, England
    Try this
    http://www.cncsimple.com/
    Free and the developer is taking an interest in it.
    Beaverton, OR
    Quote Originally Posted by Luke55
    You might try downloading the newest version of java and installing it. It runs on that and html.
