Results 1 to 10 of 12
Thread: Which drill bit for a 3/8"x16 tap?
    Oct 2009
    Louisville, KY
    Default Which drill bit for a 3/8"x16 tap?
    I'm drilling cast iron. This web page says I need a .3320" (size Q) drill. However, my Machinerys Handbook says a 5/16" (.3125) hole is called for (assuming my threads are American Standard Form...) My tap is an H3 tap if it matters.
    What's a newb to do?
    (curiously, MH says a Q is appropriate for 3x8"x24 TPI threads.)
    Nov 2002
    Maine
    I'd use the 5/16" drill and not worry about it.
    Kent Bridge, Ontario
    akk the charts I have seen say 5/16 thats what I use.
    Jul 2007
    West Michigan
    Yup, 5/16
    Texas
    My tap drill calculator gives a value of 0.3141" diameter for a 3/8-16, 75% thread. This is close to the 5/16" (0.3125") drill size and 5/16" is probably as close as you are going to get.
    The Q (0.332") drill would give you a thread that is only about 52% of the full thread form. This is a bit too small for my liking. For one thing, your actual hole would probably be several thousanths larger than the drill's size so the 52% would be reduced even further.
    CI is relatively easy to tap. I would go with the 5/16" size.
    Sep 2003
    Louisville, KY
    Going from memory, I use a letter O, .316", for 3/8-16 threads.
    Harry
    My favorite tap drill chart lists drill sizes from .307" to .325" for a 3/8--16 thread. The length of thread engagement is the determining factor in drill size.
    The longer the thread engagement the larger the drill.
    Nov 1999
    SE OZ
    Default 5/16
    Use 8mm x 1/25.4 = 0.315" ~ 0.3125" = 5/16"
    I keep both inch drills in 1/64" (0.0156") increments and metric drills in 0.1mm (0.004") increments for just this reason.
    Canada, Bc
    I use an awsome thread chart that lists 50% and 75% drill size, in both fractional/number/letter/whatever is closest form, AND in decimal form, So I can actualy use my calipers to pick out a 'close enough' bit, And see just how close a perticular bit is.
    Usally, In aluminum you want 75%, And steel/etc 50%, though I usally aim for somewhere around 60%~70% in steel.. because It makes me feel like im cheating and getting a better thread, but not stressing the tap too much with a 75% depth.
    http://www.shender4.com/thread_chart.htm
    NL
    Write This on the wall in ur shop for quick reference
    TD = D - 1/N
    and get a chart off the net...just a tip with stainless go 60 to as low as 50%
    e
    PS The book that Oldtriffie has a pic of is excellent for the price!!
    please visit my webpage:
    http://motorworks88.webs.com/
