Results 1 to 10 of 31
Thread: machining copper
    Default machining copper
    My vise needs some new jaws so I thought I would make them from copper. I've never machined copper so any suggestions would be appreciated. Will need to square up the stock, size, drill and countersink the mounting holes.
    John
    Taylorsville Ky
    Is that a bench vise or a mill vise?
    Jul 2005
    Bloomington, IN
    I hate machining copper; it is very gummy. I'd consider using something else that is cheaper and easier to deal with. How about brass?
    If you are dead set on copper, I'm sure someone here can help you. My limited experience with it has not been pleasent, though.
    Jun 2007
    Ohio
    This forum's search function returns 12 threads (including this one) about machining copper when using "machining copper" as the search criteria.
    Btw, not trying to be a smart ass or anything but just wanted to point out the search function does work well if you use the correct criteria. Google too.
    Old machinist books recommend milk ...
    Best of luck
    Jun 2002
    Grand Blanc Michigan
    Just yesterday I machined a couple of copper details for a resistance welding fixture. Took no special precautions, milling, drilling or tapping. Used ordinary cutting oil for tapping 1/4-20 threads. The metal is indeed gummy, but I had no problems.
    Nov 2009
    Ontario
    Hi John:
    I asked that question a while back and the guys told me to use Milk as a cutting lubricant! I was having trouble drilling holes in 1/4" copper plate and the milk helped quite a bit.
    I'd choose a different material for the jaws personally.
    If you buy crap, be prepared to re-design and fix it.
    vise is 4" wilton machinist. It has beat up serrated steel jaws on it and I find that I prefer a little softer jaw.
    john
    Montezuma, IA
    "I asked that question a while back and the guys told me to use Milk as a cutting lubricant! I was having trouble drilling holes in 1/4" copper plate and the milk helped quite a bit."
    Is that regular, 2% low fat, 1% low fat or skim?
    David
    David Kaiser
    Montezuma, IA
    Maine
    I assume (but don't know) that you would want to use whole milk with the butterfat in it.
    Apr 2007
    Fairport NY
    Quote Originally Posted by 38_Cal
    David
    I expect this to be on page five by the time I get back.
    Plastic Operators Dot Com
