Results 1 to 7 of 7
Thread: How do I remove plastic from brass on shotgun shells?
    pgmrdan Guest
    Default How do I remove plastic from brass on shotgun shells?
    I have a need for the brass on some shotgun shells and I want to discard the plastic. Are the plastic tubes glued on? Is there a handy solvent for this glue?
    Any ideas?
    Thanks.
    Jan 2007
    Minnesoa
    Hi,
    New shotshells are generally brass plating on steel. So if you are expecting all brass you will be disappointed.
    The plastic could be melted or even burnt out I suppose. A strong solvent like paint thinner might eat it.
    dalee
    Oct 2005
    British Columbia
    Use heat.
    Heat the brass with a propane torch or electric heat gun, grab the plastic hull with pliers, and then place the shell's rim into the jaws of an open vise and pull.
    Don't overheat the brass, it just needs to be warm enough to soften the plastic.
    Nottingham, England
    Quote Originally Posted by Willy
    Use heat.
    Are you REALLY sure ??
    This is what i saw when I opened the forum up.
    Stevens Point, WI
    Hahahahaha
    Oct 2005
    British Columbia
    Good one John.
    I'll have to pay more attention if I'm to escape your rapier like wit.
    Oct 2005
    British Columbia
    So, any luck yet?
