Hi, I tryed spraypainting some parts last week, but the paint is still dentable with a fingernail. Im using Tremclad 'Professional' enamel paint, And applyed it as follows in a 14c envorment, And have tryed putting the part infront of a heater for a few days with little effect.
the paint says to wait 10 to 20 mins beween recoats, with a max time of 1 hour or wait 48 hours
Did the following with the part infront of the heater, so it likey got 20~30c air passing over it.
Painted 3 layers of primer, with 15 mins wait time beween, The coats where think enough to have good coverage, but not quite 100% coverage with each coat, more like 75%, so no runs.
Waited about 10 extra mins for the paint to dry, then fliped the part over.
painted the back side with 3 coats of primer, 15 mins inbeween coats.
Waited about 10 extra mins for the paint to dry, then fliped it back over.
painted 3 coats of black, 15 mins apart, about the same coverage as the primer each coat.
So basicly I put 3 coats of primer on each side of the part, and then 3 layers of black semigloss topcoat, with about 55 mins beween primer and topcoat.
One thing I noticed was even after 25 mins, the primer still not fully touch dry, and where the primer contacted the block it rested on, it riped off on the next part flip. So I guess I really do have to suspend the parts and paint both sides at once.
Now, my main issue with the resulting job, is its just still soft even after a week of drying infront of a space heater.
Should I have used thinner coats? It seemed pertty much 100% coverage after the 2nd coat, but I put a 3rd on to insure it was thick. I want a durable paint and assumed thickness+number of coats is the way to get it. Is that wrong?
Should I wait the 48+ hours recommended after X number of coats? What is X number? Should I wait even longer?
Should I do less or thinner primer coats and let it dry before topcoat?
Does a primer even need 100% perfect coverage or should it be more like a very light, slightly spotty coat?
Never had any trouble with the old 7400.
