Results 1 to 6 of 6
Thread: Ball Bearings
    Default Ball Bearings
    What is the proper way to grease a ball bearing?
    Albuquerque
    Quote Originally Posted by joe826barnett
    How far is up? Why is a duck?
    Come on we need a lot more info than "a ball bearing".
    ...lew...
    Jun 2008
    NSW Australia
    As to amount, most bearing places recommend 1/3 of the free space.
    Dave
    Nov 2010
    Red Deer, Alberta
    Greasing or packing a bearing is what you want to do. The grease must be forced into and through the bearings and cage holding them. Be generous in the amount of grease but not to excess. Of course the bearing must be cleaned and dry of old grease, dirt, etc.
    It depends on what the bearing is being used for to consider the type of grease you need to pack it with. It is best to get a high quality wheel bearing grease especially if the bearing is to be used in a heavy, high speed application. If not, it won't do any harm. Likewise, you should use the grease required by the manufacturer of the item using the bearing. This is highly critical in greasing any bearing - do not make a misjudgement on the type of grease. Inspect and replace any seals that may be used in the assembly as necessary.
    Hope this helps.
    Apr 2010
    Central Indiana
    Default Packing Bearings
    Joe, If these bearings are to be used on mower deck spindles or in any other potentially wet environment - Do Not use a Lithium grease because it absorbs water.
    Nov 2006
    Louisiana
    Quote Originally Posted by Amigo
    NLG#2 lithium complex grease is recommended by Cub Cadet. It repels moisture.
