Originally Posted by
Toolguy
If you have digital calipers, put the inside jaws in one hole, expand as if measuring the hole and zero the readout. Then put the same jaws from one hole to another and expand to fit. The reading is the center to center distance because you have already subtracted one diameter. This works on smooth or threaded holes if they are both the same size. You can zero the caliper with the jaws closed and measure hole to hole with the outside jaws and add one hole diameter. This method is accurate enough for most jobs. Technically, it is not exact because the flats on the jaws create a small chord on the circumference. Usually the difference is so small as to not matter.
