Results 1 to 10 of 28
Thread: Gear pullers get me cussin'!
    Nov 2009
    Blue Springs MO
    Default Gear pullers get me cussin'!
    I have several gear pullers from little bitty ones to some pretty good size ones. They all have one thing in common. They have more moving parts than I have hands. I hate to have to ask some one in the shop to come help, but I have never found a good way to hold 3 or 4 legs on a gear or pulley with one hand while trying to tighten the screw. It gets even worse if I'm using a end protecter under the screw. What are some of the tricks you've found useful?
    Scotty
    Netherlands
    Use the spring loaded ones, even I can use those
    Igor
    Stevens Point, WI
    That spring one looks nice!
    Some of my puller have a nut on the top that hold the fingers tight against the gear while you turn the screw down. Rubber bands around the fingers work great. Tape sometimes works. Some of my screws have a soft aluminum insert end that snaps onto the screw so I don't have to try and hold it while turning the screw.
    Kent Bridge, Ontario
    I just bought a large one by Gray Tools. Arms lock on even when the part pulls off the puller stays on. Saves from having to catch the puller and the 60 lb wheel at the same time.
    Sturgeon Bay, WISCONSIN (near Green Bay)
    Quote Originally Posted by ScottyM
    Scotty
    If you're like me and have, shall we say, the economical sets, I use rubber bands to accumulate the arms....that is I did before I snapped the linkages of a couple attempting to pull a stubborn item. #$^@ cuss.
    John M...your (un)usual basement dweller
    Jun 2006
    Austin, Texas
    I hook one of the top legs onto the gear/sheave and tighten-up the screw enough to hold it on, then squeeze the other legs on while tightening the screw the rest of the way by hand (i.e., until all three or four legs stay on from tension).
    Never had a problem doing that, but the spring-loaded version looks nice
    Nottingham, England
    Change religion then you have no more problems
    Nov 2009
    Blue Springs MO
    That spring loaded one looks nice, but I would hate to have to replace all of my sizes with those. I could see that getting pretty pricey real quick. I'll give the rubber bands a try next time. But if anyone has more ideas I'd sure like to hear them.
    Scotty
    Nov 2009
    Blue Springs MO
    Quote Originally Posted by John Stevenson
    Good idea John, but do I have to wear that outfit too. Man the guys in my shop would never let me hear the end of it.
    Scotty
    Mar 2010
    Smile
    honestly would you want a woman with that many hands?
