Results 1 to 7 of 7
Thread: Working plate
    Default Working plate
    So I bought a motorcycle. Thought I'd futz with the techniques for making stuff for it. I turned a set of handlebar risers for a friends bobber and they turned out rather nice.
    Looking at the sissybar, it's roughly 1/4" steel, cut, bent, and chromed.
    How would a home shop fella duplicate it? Would the cheap, clamp to your workbench, Harbor Freight metal brake be able to bent 1/4" steel? I'd imagine duplicating a symmetric shape might take a little practice.
    I'll bet I con convince the minimill to plunge cut and form cut-outs.
    I figure I'd farm out the chroming, how perfect does the surface of the metal have to be to take a good chrome?
    What are your experiences?
    Dec 2002
    Friesland, Netherlands
    When you say "1/4" steel", do you mean solid round bar, solid square, 1/4" wall thickness tubing, 1/4" plate...?
    Ian
    All of the gear, no idea...
    Dec 2006
    iowa
    [QUOTE=rocketsled]
    QUOTE]
    how perfect do you want the chrome ? every flaw in the base metal is magnified in the chrome
    Nov 2010
    Lafayette Indiana
    Watch a few of the custom bike shows on TV and you will learn how crude you can be. Many sissybars back in the day were formed using not much more than a hammer, vise, and torch for heat to assist in the bending.
    Quote Originally Posted by Ian B
    Ian
    1/4" plate (hence the thread title)....and it's actually not to make a sissybar, I've got some people interested in altering the shifter for biger and smaller feet, and it's made from similar gauge metal.
    Gotcha...good to know.
    Louisville, KY
    Moving the shifter is a heat-and-beat job in the vise or possibly a bender of some sort, not a brake. Lots of home-made benders floating around, that's what you've got a lathe for Gentle curves can be formed with a three-point bending fixture in a press.
    I've seen sissy bars made of everything from paper thin tubing up to 3/4" square solid bar. Better descriptions or pictures will get you better advice.
    Chilliwack, B.C.
    Usually when you talk about a metal brake, it's not going to be something able to bend 1/4 inch thick material- not even close. A metal bender, possibly, a press- probably easily. A brake is for sheet material, and it will take a pretty good sized one to handle even 1/8 thick material of any real length. Something like that would easily bend 1/4 inch material of normal widths, say 2 or even 3 inch wide bar, but the adjustments would not be in the right range. It's not the machine for that job.
