Results 1 to 10 of 16
Thread: Chip breaker not chip breaking!!!!
    Apr 2009
    Columbus Texas
    Default Chip breaker not chip breaking!!!!
    Well something like that. I hardly ever push my lathe hard at all. But I was in a hurry to night and all I had was some old hydraulic rod that was about ˝” to big. So I turned it down with a negative rake, chip breaker insert. I ran it at 600rpm .100”doc and .0045”ipr. But still ended up with a bird nest. With direction do I need to go to get small chips? The rod was 2.5”OD
    Default Chip Breaker
    I would try pushing the feed harder. Even if you have to back out to .05 or .06 on the depth of cut. Hard feedrate is what makes the chips break.
    Taylorsville Ky
    Depending on the metal, DOC, feed and rpm a chip breaker may or may not break the chip. When I am turning something at a certain DOC, feed and rpm and the chip doesn't break I try hand feeding the cut to see if slower or faster will do the job. Sometimes I have to increase or decrease the rpm as well to find the combination. That's the fastest way I have found to do it. Using auto feed and changing everything takes to much time to find the right combo.
    Of course you have to be a good judge of how fast your feeding by hand to convert it to the auto feed but you can get close and fine tune it.
    Phoenix, AZ
    I had some 4" dia tool steel I got for a project (some seemed to thing 4340 IIRC) that did not want to break a chip. And I had to drop the OD on the end to thread 30mm (LH) while reducing over all diameter to just over 3" for about 3" length. I played around a bit and finally got it making nice heavy tight blue chips about 4" long. The final setting was something like 0.375 DOC with 0.024 feed and about 400 sfpm. Tried several different inserts too. Of course, by the time I had it running nice, I was about done...
    Russ
    Master Floor Sweeper
    Canada, Bc
    Adjusting the tool (post) angle can make a big diffrence too.
    But yea, I find more RPM's, Higher feed/doc often get the chip to break. Some materials just need more serious chipbreakers too.
    Jul 2009
    SF bay area, CA
    First of all, you need to mention what insert you are using. Different inserts are designed to break chips at either roughing feeds or finishing feeds. One of the Sandvik technical guides had a section about chip breaking, although I can't find it right now.
    Sep 2009
    Spencer MA USA
    Quote Originally Posted by beanbag
    This is correct.
    In this case (shown in the photos) the problem is far more likely to be an overriding the chipbreaker problem. Increasing the feed rate isn't going to help,it's going to make it worse.
    A DNMG insert is usually used for profiling or finishing, but there are some with roughing chipbreaker designs. I have some. Each reputable manufacturer publishes depth-or-cut and feed rate data for each of their chibreakers...somewhere. I have a pretty good chart myself showing many, but it's a HUGE file that I can't share, sorry. What I can do is help. If you tell me the spec of the insert you have, I'll see if I can find the data for it.
    Failing that, you can often find the charts for this on each mfr's website or certainly in their catalogs. Most times you can download a PDF of the catalog if you can't ask them to send you one.
    In the course of applying carbide insert tooling to turning applications, you match the grade and coating and the cutting speed to the material type, then the chipbreaker to the desired depth of cut and feed rate. Sometimes you find that a maker doesn't have a chipbreaker that works and in the grade that does, or vise-versa. That is why we gt so many choices.
    A home shop simply cannot have a wide array of different grades, coatings, chipbreakers and sources. It's too expensive and we have nowhere to put them. What we can do if find a couple of gems that work well for 90% of what we do, and learn how to use them.
    For the problem at hand the solution would likely be to take a shallower depth of cut and try feed rates of .005", .010", and .015" per rev to see which provided the best chip form. Adjust from there until it works.
    Nov 2002
    If you look at the linsert the land on the edge of the tool is were a lot of the problems with chip breaking/bird's nest come from. The feed has to be agressive enough that the frazcture point of the material is high enough above the cutting tool (the material actually fractures instead of "cutting") that is flows past the land and into the channel that froms the curl.
    Apr 2009
    Columbus Texas
    It was a US made generic TNMG insert.
    Sep 2009
    Spencer MA USA
    Quote Originally Posted by jeremy13
    And so you got US made generic chips from using it.
    You get what you pay for.
    If you were to post a close-up photo of the insert, I might be able to match it up to a chart I have and give you some depth-of-cut and feed rate recommendation for it.
