Results 1 to 10 of 14
Thread: Drilling Crossholes Through Round Stock
    Default Drilling Crossholes Through Round Stock
    OK, this is terribly basic but it's something I have a hard time getting right. What's a good way to get a hole right spang on center through a round workpiece? I'm faced with having to make new pushrods for some small hydraulic cylinders and need to drill through the rods for crosspins. Holes willl need to be clearance for .500 and .5625 through 1.00 and 1.125 stock respectively. I've got a few options, drill press with loose vise, Smithy combo machine using the mill setup with a drill chuck and vise mounted on the lathe carriage, and a Bridgeport with a super solid, bolted down, vise and DRO.
    The Smithy and BP aren't mine but I have free access to them. While I've done some crude crossdrilling it has never been anything that really should come out right on the money. All suggestions appreciated.
    Feb 2004
    Use the BP. Mount work piece in vice, horizontal with the table and with end that you want to cross drill hanging past the end of the vice an inch or two.
    Mount a drill chuck with a piece of drill rod in it. Lower the drill chuck until the rod is just below the bottom edge of the stock to be drilled. Move the cross slide until the drill rod makes contact with the stock. I use a piece of shim stock between the drill rod and the stock moving it until it's just pinched to determine when contact is made.
    Set the cross slide a to "0". Now add up the diameter of the stock you are drilling and the drill rod. Divide that number by 2. This gives you the distance to move the cross slide to be dead center on the stock. NOTE: if you use a piece of shim stock to determine contact you need to include the thickness of it in your calculation.
    Mar 2010
    Chicago, IL
    My vote: use the Bridgeport to make a top/bottom vee fixture to fit drill bushings* to guide your twist drill on the drill press. Similar to this example, made by Heinrich: http://www.heinrichco.com/drill_jig_hand-op.htm
    *http://www.mcmaster.com/#drill-bushi...liners/=bepht7
    Mar 2010
    Chicago, IL
    Also note, given portlandRon's suggestion: if you are going to drill without a guide bushing (as above), you MUST use a spotting drill first. A twist drill will wander on a curved surface. Spot. Then drill.
    Jul 2001
    Green Bay, WI
    First , you need a V Block that is locked to the table somehow, and the drill bit be centered on the bottom of the V. (use your quill stop just short of hitting the bottom). Once set up, never move it
    2nd, Clamp the rod so it does not move once you start
    3rd, start your hole with a ball mill (least deflection of any cutter) or a spotting drill, the same size or smaller than the finish drill. Center drills also work, but are not as accurate as the first two. Never use the drill bit to start on a curved critial surface, except it is OK after punching through the top
    for the tube bottom as the surface is concave. Do not predrill the bottom undersize, unless you spot drill it first.
    I think this should work for your.
    No freehand drilling !
    Rich
    Nov 2009
    between san antonio and mexico
    once i have x and y set and dial settings Written down, i mill a flat across the top using the Y feed. use a mill equal to or slightly larger than your finish drill size. youre looking for a square,flat spot on the top of your shaft.
    Oct 2008
    NONE U BIDNESS
    If the DRO has a 1/2 key just edge find one side of stock, zero that axis, edge find other side of stock, press 1/2 key.
    The reading on the DRO will be the exact center of your stock, so just move the table until DRO reads 000.
    Drill hole.
    THANX RICH
    People say I'm getting crankier as I get older. That's not it. I just find I enjoy annoying people a lot more now. Especially younger people!!!
    Chilliwack, B.C.
    I did a setup on the mill at one time that seemed to work pretty well. Instead of a pair of V blocks, I used a pair of shop made L blocks. Each has one flat surface with a vertical tab rising from it. The rod to be drilled is set against the tab and clamped. The edge of the tab gives a reference surface when you're dialling in the mill table. I found it easier to set up, especially where you don't have much vertical range without cranking the head up or down, and probably losing your alignment at the same time (round column mill owner here). The L blocks were made from angle, with one side cut down to a manageable height, and the other side previously milled to be flat so they could sit flush on the mill table without rocking. I milled them in place, clamped to the table side by side. I wanted to key them to a t-slot, but didn't take the time to do it.
    You can easily align the blocks to the x axis by using the reference sides of these blocks. If this is done, you won't have to worry about losing your center alignment point when you crank the x axis to position the setup for the actual drilling of the cross hole. You can also set up a stop on the mill table to help keep holes an equal distance from the ends of multiple workpieces.
    I have a few precision rods that I can mount in a drill chuck or endmill holder- I use these in combination with zig zag papers (.001 thickness) when picking up an edge. Drag the paper between the rod and the reference surface while cranking the table over- when you start to feel the drag on the paper, you know you're 1 thou away. Set dial at .999, work out the math, crank the table over the right amount to center the workpiece, remove rod, mount cutter, etc.
    By the way, if you need two or more holes in the same piece, but want to keep the mill table axis clamped during the whole process, you can insert a close fitting rod into one drilled hole, then use that with a 123 block or similar to assure an accurate vertical there so that subsequent holes are in line with the first.
    There's one more thing I thought of at the time I made these L blocks- because I was drilling right through the diameter and didn't want to muck up my fixtures, I had the workpiece overhanging the block. A support block under the very tip would have been a nice way to alleviate the possibility of the workpiece tilting from the drilling pressure. The support block would have been machined at the same time as the L blocks so the flats would be at the same exact height. I did not take this step at the time, but I wished I had done so. I might just make up another kit of these, making it complete at this time. Thanks for the reminder-
    Maine
    These days how I do it is clamp the rod in the mill vise and use my DRO's centerline function. Indicate the back jaw of the vise, then the front jaw, and the computed centerline is the centerline of the rod.
    Before I had a DRO I used a long-reach Starrett wiggler with its 0.50" edge finder attachment to indicate one side of the rod, then I computed how far to move over to be on the rod's centerline.
    Mar 2010
    Smile
    Quote Originally Posted by portlandRon
    thanks i needed that i tried it this morning and it worked fine at last i can drill a hole in the center of a round rod one more lesson learned thanks jack
