Results 1 to 10 of 14
Thread: quick release quill nut
    Nov 2006
    durban s africa
    Default quick release quill nut
    I got tired of having to spin the nut for the depth stop on my milling machine so I stole this idea from my mate Werner. Now its real quick to adjust the depth stop. I soppose this could be more refined by making a fine adjustment nut to fit on the sliding stop. I am thinking of putting a nut to fit this with a 1mm pitch
    Aug 2007
    Nice.
    Quote Originally Posted by plunger
    Or you could use the knee, which already has a graduated dial.
    Which is as I understand the right way to go.It's not a mill drill is it? Alistair
    Maine
    Now *that* makes a lot of sense! Thanks for the inspiration.
    Nottingham, England
    Quote Originally Posted by noah katz
    Nice.
    What happens when you have the head angled ?
    Something that has always puzzled me on the Bridgy, it's supposedly a toolroom machine but nothing other than a 5" rule on the head ?
    Graduated dials on X and Y but the quill is ignored.
    Yes I know you can mount the work at the correct angle and move the knee and if this is the case why not fix the head solid so you don't have to retram it every 23 minutes.
    Oct 2005
    Lower SE Michigan, USA
    John,
    If you'd quit abusing your poor B'Port, it'd easily go an hour, maybe 2 before needing to be retrammed. Mine does.
    Feb 2009
    Seattle, WA
    ...because, in the words of one of my friends who used to do this for a living-
    "Bridgeport? They make drill presses."
    When the quill slips in the middle of a cut, I find little reason to disagree with him...
    heh
    t
    rusting in Seattle
    Jan 2007
    Minnesoa
    Hi,
    Yeah, it's the drill press thing Sir John. 5" of stroke matches pretty well to many "standard" sized drill presses.
    Tobias, your friend left off the part about Bridgeport making some of the worlds most accurate workbenches too as well as an only fair to middlin' drill press.
    dalee
    Nottingham, England
    Quote Originally Posted by jdunmyer
    John,
    It's not abuse it's using it to the design limits
    Speaking of which I'm doing a pump stub shaft at the moment, started off today with a solid piece of steel 10" diameter and 12" long, 6 hours later I have this top hat shape and a skip full of turnings.
    On the big top hat it needs 12 holes 7/8" clearance with 6 of them counterbored to 1 1/2"
    Just fits on the Bridgy standing up now I have turned a 23mm drill down from MT2 to 16mm and chopped 5" off the end
    Then got to mill two 7/8" keyways in at 90 degrees to one another.
    The things I do to earn £5.76p
    Nov 2006
    durban s africa
    Its not a bridgy Its an mitco iso 40. Proudly made in s africa. Or at least was made in s africa .This was made in the late 70s early 80s during the apartheid era when s africa was isolated because of sanctions. I hope I never need spares. Its based on the holke design which I think is spanish.
    If I am drilling a lot of 4mm holes I would not like to have to use the knee if I could help it.
