Results 1 to 6 of 6
Thread: Taperlock dimensions
    Aug 2010
    Emerald Qld Australia
    Default Taperlock dimensions
    I went to make a small taperlock for a shaft and have found that some of my charts were lost in the flooding which we experienced around Christmas.
    I was wondering if anyone would have the links or some other way of getting this info again.
    Thanks in advance
    Michael
    Nottingham, England
    Somewhere I have drawings for the 1008, 1108, 1210,1610 and 2012 series because I have made jig plates to enable me to fit these to whatever.
    Can you handle DXF files? if so Pm me an email address.
    Toledo, Ohio
    Canada, Bc
    Why does the mating part only have 1 hole for 'R'?
    Im assuming the R holes are for Removal, and the insert has two threaded R holes. But the mating part only has one R hole (Well, ledge?), How do you remove a locked taper peice with only one removal lift point off center? (Doesnt it get 'cocked' in the hole due to unequal force? Or does that not happen because its a taper?)
    Also, What does C stand for? lol.
    Aug 2010
    Default Taper locks
    Quote Originally Posted by John Stevenson
    PM sent , thanks.
    Michael
    Aug 2010
    Default Dimensions .
    Quote Originally Posted by JCHannum
    Looking atthat now , if its printable it will be great , thanks.
    Michael
