Results 1 to 10 of 16
Thread: Best bang for the buck caliper?
    Jun 2010
    Twisp, WA
    Default Best bang for the buck caliper?
    My current cheapie digital caliper is getting a bit flaky on me, and my work is improving to the point where a more precise tool is reasonable. I don't mind spending money on quality, but I'm not made of the stuff, either :-). Any suggestions for a solid, repeatably accurate digital unit that won't break the bank? Figure a budget under $200, and closer to $100 would be better. Auto off would be nice, and switchable metric/imperial is a must. Don't need solar powered or computer output. Thanks, gents.
    Dave
    Jan 2006
    Kansas
    For roughing in cheap calipers work fine but you need to get micrometers for precision measurements.
    Owensboro KY
    Quote Originally Posted by J.Ramsey
    Ditto.
    However I have a Brown & Sharpe 6" digital caliper that's going on 20 years and works as well as it did on day one. I also baby it by keeping it clean, in the box when not in use, have never dropped it (knock on wood), and keep it away from abrasive environments (grinders, cast iron, etc).
    Dec 2003
    Palo Alto, California
    I've used and abused my Mitutoyo 6" caliper and it has outperformed and outlasted generations of cheap Chinese ones in our busy guitar repair shop. Battery life is many times longer, too.
    Here's some interesting reading on the subject of electronic digital calipers:
    http://www.fliptronics.com/tip0006.html
    Frank Ford
    HomeShopTech
    Aug 2007
    Monroe,GA
    I'll second the Mitutoyos. I have the enco# 610-0045. No auto shut off, but the battery has lasted over two years now, mainly because tt really does shut off when you press the off button.http://www.use-enco.com/CGI/INPDFF?PMPAGE=344&PMCTLG=00
    Ted
    Feb 2004
    I like the Mitutoyo calipers,I've had cheap ones and they always need the zero resetting,plus the Mitutoyo are a lot smoother in action,they just feel a lot better quality.
    Allan
    Sep 2008
    WI/IL border
    Mitutoyo are very good. I never tried a digital Brown and Sharpe, but their manual calipers are excellent.
    Albuquerque, New Mexico USA
    +1 on the Mitutoyo Digimatics.
    I've got quite a few around so I don't have to go looking - I got most of them through eBay auctions buying non-working calipers (bad jaws + working electronics and good jaws with bad electronics) and mixing-n-matching the electronics and calipers to get working sets. To get away with that you need to buy the same model basic numbers so the case holes match the electronic board button locations but in the end I got half a dozen for the price of 3 on eBay (best buy ever: carbide ID & OD jaws with NR electronics for $20, replace with $15 caliper electronics).
    I don't like the newer coolant proof models as much as the old 500-19x series, and in that I prefer the ones with the buttons on the front edge of the case over the ones with the buttons on the face of the case.
    (OK, I totally geeked out on calipers there. Sorry.)
    Taylorsville Ky
    Best bang for the buck is the Horrible Freight dial calipers. I have tried them all and for general use they are best.
    I keep two spares on in reserve new and have two I use daily. One is for rough stuff and one is for good measuring.
    No matter how much you spend for dial calipers they are only good to +/-.001" so think of them as expendable and cheap enough to throw away.
    If your measuring for close tolerances use mikes, for rough measuring use calipers, dial or vernier.
    Jun 2006
    Austin, Texas
    Another vote for the Mitutoyo -- I have the silver IP65 calipers and they're bulletproof despite a lot of rough use.
