Since I recently bought a Canon 60D I have a spare dSLR lying around, my old Pentax K10D. It not particularly valuable so I decided to convert it over to IR. This is the third one I have done. Forst was an old Kodak DC210, then I did an electronic modification on my Sony DSC-v3 that allowed me to move the hot filter out of the way with a tiny button.
This one was a bit more complex. Lucky for me I had the service manual for the camera.
Took the camera's case off. Desoldered the main board and removed it. Then pulled the CCD block off. This block holds the sensor as well as the linear motors that do the shake reduction. I then removed the clip that holds the IR cut filter in place and pried off the IR cut filter. It was held in place with a adhesive foam gasket.
K10D Infrared Conversion by macona, on Flickr
The IR Cut filter was only 1mm thick. The IR filter I had planned on using was 2mm thick. I found a dichroic filter made for astronomical use and they are only 1 mm thick. I got it and cut it to size with a diamond ring saw. Unfortunately the corner broke. So I just cut the thicker one to size and used a diamond file to fine tune it.
