Results 1 to 9 of 9
Thread: How to BUILD your own Demagnetizer
    gary350 Guest
    Default How to BUILD your own Demagnetizer
    I built a demagnetizer about 10 years ago. This is just a flat coil of wire and a light bulb. The light bulb is what determines the power rating of the magnetic field. If you want a lot of power us a 100 watt light bulb but if you only need a small amount of power use a 25 watt light bulb. Connect your power cord, light bulb, and coil all in series. You can use the light bulb as the switch just screw it in for ON then unscrew for OFF. If you don't want to burn your fingers in a hot 100 watt bulb then use a light switch to turn it ON/OFF or unplug the cord. This is how it works, you need to over come the magnetic field you are trying to remove so you only need a little power for things that are slightly magnetizer and you need more power for things that have more magnetism. A 100 watt light bulb produces a large magnet field you need to pull the part about 4 ft away from the demagnetizer to remove the magnet field. A 40 watt light bulb produces a smaller magnetic field so you need to pull the part away about 2.5 ft. See the photo at the top.
    If you want the Rolls Royce version add a Variac in series with everything you no longer need the ON/OFF switch. Turn the power UP then turn the power DOWN very slowly. No need to pull the part off by hand and pull it way back away from the demagnetizer. You can use a 100 watt bulb all the time so if you only need a little power then turn the variac up about 50% for half power then very slowly turn the power down. See the second photo.
    I made 2 of these coils and I built one real nice demagnetizer in a 1/4" plywood box. It worked great then I got the idea maybe it would sell on ebay and it did for $95. I have been planning to build the other demagnetizer but I keep putting it off. Sorry but I never took a photo of my finished demagnetizer. I am getting older and my projects are a lot slower getting finished.
    The coil is made from #24 enamel coated copper wire. It is 1/4" thick and about 5" diameter probably about 1000 turns of wire. The center of the coil is a piece of 1" diameter PVC pipe 1/4" thick. I clamped 2 pieces of plexaglass over the PVC piece and turned it in the lathe to wind the coil. You need to paint the coil as it winds up with Polyester Resin or 30 minute Epoxy so the whole thing gets hard and holds together as one solid piece. Put a good amount of epoxy on one side of the finished coil and glue it to the under side of your 1/4" plywood. I put my light bulb on the right side and the light switch on the left side and build it all in a nice little wood box about 2.5" tall. If you use the variac your box will have to be larger. I experemented with the variac but never built it onto a box. I had the variac setting off to one side and it works great.
    northwest wisconsin
    could a guy use a half field coil from a power tool like a drill ?
    Bremerton Washington
    Built a half dozen from 1 KVA control transformers I pulled from the dumpster. Delaminate, arrange the "E"s as a stack and run an autogenous TIG weld across the lams to hold them together. Insert in the coil, wedge/bond to secure. Connect 230/460 windings in series. Wire 460 winding to 115 V plug and switch. Install in non-magnetic electrical enclosure with the open side of "E's in contact with the smooth side.
    Precaution: bond to the iron a self re-setting 100 degree C snap action switch in series with winding. Tidy up to comply with NEC like tape off unused electrical connections..
    Refinement: install a suitable Variac or an SCR AC fan control for variable power.
    This gives you a demag area abou 3" x 5". They loved them in the surface grinders where the permaanent mag chucks left residual magnetism in the work.
    Apr 2010
    Canada
    Here you go ebay 99c 280667699115
    There must be a few discarded now, now that CRT TV's are pretty much out!
    Max.
    Jul 2007
    Default Demagnetizer
    I understand that if you remove the armature from a shaded pole motor, install the remaining unit on a board with a momentary switch, it makes a good unit, particularly for screwdrivers, etc. Of course, you are limited by the size of motor, as to the size of tool that fits in the field opening.
    Duffy, Gatineau, Quebec
    Taylorsville Ky
    Yes, take a single phase motor and strip it down. use the coil with a light bulb or variac to control the power. You pass the part to be demagnetized through the coil.
    Aug 2004
    Default Motor less rotor
    I've also done a couple using the stator from a single phase motor. It works fine. I've even had one cheap chinese clip on fan that had a field that reached out about 3 feet when running. It made my computer monitir dance and when held up against the side of the fan, it would degauss small tools, micrometers and calipers.
    52N 122W Western Kanuckistan
    What Forrest said except you don't have to go to all the trouble of rearranging the laminations. Just cut off one end of the core of any 120 vac transformer with a bandsaw being careful not to nick the windings. Tape off the secondary windings so they aren't connected to anything and so they won't short out. Then put the unit on a foot switch and you are done. Don't run more that 10 seconds out of 60 to be on the safe side or it may let the smoke out. Some cheap transformers make it even easier since the laminations aren't interleaved. Instead the "I"s are all on one end in a block which you can simply take off.
    Jul 2006
    Livermore, California
    Safe and effective when used as directed
