What size round hole should I make in 6061 AL so I can press fit a 5/16-24 locknut into the hole. I want to be able to use the enclosing aluminum to spin on/off the nut and tighten it down.
Probably similar to a plastic knob with a metal insert. I don't want the nut slipping in the hole.
Are there different ways to achieve the same goal?
Thanks.
- T
