Results 1 to 10 of 13
Thread: Better Brakes Required!!
Hybrid View
    Sep 2004
    Default Better Brakes Required!!
    Motorized Bicycle project needs better Braking System. I have a 80 cc engine and the brakes sort of suck. Its a Giant Mountain Bike No Suspension Model. Any ideas guys ? Thanx Mike
    Jun 2008
    NSW Australia
    I fitted 8inch mountain bike hydraulic disc brakes to my sons BMX bike 6-7 years ago. It took a bit of machining to get it on the wheel and welding for the caliper mount but they worked great.
    Mountain bikes come out with these so you might pick up one cheap at the local big store to take the parts off. Over here in Aus they can be had for around $100-150 on special with mechanical discs front and back.
    The parts and the wheels would cost you that if bought separate.
    Dave
    Mar 2009
    St Augustine, FL
    Bling rim brakes:
    http://www.universalcycles.com/shopp...2&category=670
    Although for some reason I am doubting that the bike is new enough to have disc compatible rims, but if it is:
    http://www.universalcycles.com/shopp...hp?category=24
    May 2011
    Surrey, England
    Default Disc-compatible rims?
    I thought that the "Disc-compatible" rims were more "caliper-incompatible" as they're made without the parallel faces for rim brakes to grip? If anything the caliper rims are likely to be stronger (albeit heavier), being deeper section. Track racing (i.e. banked track) bikes used to have similar rims with a hollow triangular profile as they didn't need brakes and wanted to be as light as, I suspect I may even have a pair somewhere although the tubular tyres (glue-ons) have probably rotted to dust by now
    Disc-compatible *hubs*, however, would need to be stronger as they'd have torque from assymetric braking force applied to one side though the hub body to the flanges which in turn would need to be stronger to support higher loads through the spokes.
    Dave H.
    Mar 2009
    St Augustine, FL
    I stand corrected .. I should have said "wheels" not rims.
    Odds are that unless it is a custom built bike, he does not have disc hubs unless he already has disc brakes.
    The other major factor for disc hubs the the mounting flange for the disc itself.
    May 2003
    52N 122W Western Kanuckistan
    It's possible to make an adaptor for non-disk hubs to which a disk may be attached. I have done it. I don't have any pictures at the moment to show but I will see about that later.
    L&S Industries sells grinding wheels Made In USA, all types and sizes. Also Superabrasive diamond and CBN wheels, no extra cost for custom wheels, Made in Canada. 10% discount for HSM members. Call Janet 250-392-3393 08:00-12:00, 13:00-15:00 M-F Pacific Paid Ad, updated Apr 01 2013
    update 2013/3/31 . Free software for calculating bolt circles and similar: Origin now settable to bottom left! All values positive. Click Here
    Nov 2009
    Winchendon MA
    When I bought my Cannondale it had caliper type brakes but the hubs were machined for disc brakes, I had them convert it before it went out the door, my street bike has caliper brakes and compared to the disc's its like dragging your foot to stop.
