Page 1 of 6 123 ... LastLast
Results 1 to 10 of 51
Thread: Circle coordinate calculator: New updated more flexible version
    Vancouver's Island
    Default Circle coordinate calculator: New updated more flexible version
    A comment on the previous thread started me thinking about how to improve the utility. It now is much more flexible in specifying the arc length and position. It also now will calculate the length of a flat (chord) for any number of flats (max 360) within any arc up to a full circle.
    It is only 41kb
    http://ixian.ca/server/circlecalcv11.exe
    Jun 2007
    Houston Texas Area
    Thanks Evan.
    Dwayne
    "When it comes to paradigms ... shifts happen" - Alain Rossman
    Feb 2006
    Phoenix
    A worthy improvement, but with a bug in the angle readout.
    Allan Ostling
    Vancouver's Island
    What bug?
    Feb 2008
    Ashcroft, British Columbia
    3131.0 line 7
    Ernie (VE7ERN)
    Vancouver's Island
    Using exactly what settings? It is probably a formatting error. Just curious, does a value of 313.1 make sense?
    Dec 2006
    iowa
    Evan, look at the screen shot you posted
    Feb 2006
    Phoenix
    The angle values should be
    231.00
    244.83
    258.66
    272.50
    286.33
    300.17
    314.00
    327.83
    341.67
    355.50
    009.33
    023.17
    037.00
    The ones indented printed out erroneously.
    Allan Ostling
    Vancouver's Island
    Download it again and try it. I found a small roundoff error for certain values that produce formatting problems.
    Without knowing the settings you used the results aren't meaningful.
    Unfortunately, computers do not always produce accurate results even for rational numbers. This because the math is done in binary and then converted to decimal. For instance, In binary 0.001 is an irrational number.
    Feb 2006
    Phoenix
    The corrected values shown above are for the settings in your OP. I cannot download it unless you make a Mac version.
    Allan Ostling
