2) One noise is slightly before, or possibly just after my foot has let up during a start, (squeal) and clutch is just matching speed, or just HAS matched speed.... it lasts a good drawn-out count of "one", so it isn't precise.
Has to be a fairly abrupt start to do it, and it helps if it's hot. NEVER does it if the weather is wet.
Mechanics didn't find it, I had to show the shop manager (a non-stop talker) the noise, and he tried initially to tell me I was squealing the tires...... FAIL! Eventually the torrent of words got down to a "I don't know exactly what it is, there's no inspection plate on that tranny so I can't look easily, but it doesn't sound like you need to fix it now".
I almost put it down to a belt squealing as the engine slows when starting up, but there is just one big belt, which, while a bit glazed-looking, is tight enough, and never makes any known "regular' belt noise.
