I have had this 4'X8' sheet of what is apparently salt water corrosion resistant Naval brass(or bronze) for years. This could be aluminum bronze. I am sure it is salt water corrosion resistant stuff. Came out of a Navy yard auction years ago. The guy who bid on it thought he was buying a pile of sheet metal,and this 1/2" sheet was inside the pile.
It has a beautiful golden color to it,and it is tough to cut.
I made a cannon out of a 5" bar of the same gold colored brass(or bronze).
Do I have to invest over $300.00 in a Milwaukee metal cutting circular saw and blade to cut it,or would a cheaper saw of similar amperage and RPM be suitable? After I get the brass sawn up,I'd have no further use for it,so I hate to spend a lot on it.
I'd obviously have to put suitable guards over the open side of the blade.
This sheet weighs about 800#. All I need to do is get it cut into more manageable size pieces so I can get it onto my Roll In bandsaw,where I have HSS tipped blades.
Any suggestions? Years ago I bought a good saber saw to try to cut it,but after quite a while,I only made it about 9",and stopped,afraid I'd ruin the new saw.
