Results 1 to 3 of 3
Thread: OT pulling a milling face
    Feb 2011
    South Africa
    Default OT pulling a milling face
    I know this way OT but have ask is it just me or does milling tend to cause you guys to pull a funny face.
    From time to time ( when thumb sucking my doc and feed rate) I get is so bad my jaw starts to hurt.
    Is milling surposed to be relaxing???
    Westline
    If you are using violence and it does not work, You are not using enough.
    Feb 2009
    Belgium
    If you mean to grimace, yea.
    That's why machinists need lots of beauty naps. ;-)
    Wear eye protection!
    So you can relax your squinting.
    Danny
    Wer anderen etwas vorgedacht, ....... When you propose a solution for someone's problem,
    wird jahrelang nur ausgelacht. ....... you will be ridiculed for years.
    Begreift man die Entdeckung endlich, ....... When the discovery is finally understood,
    so nennt sie jeder selbstverständlich. ....... everyone will say it is obvious.
    -- Wilhelm Busch --
    Central Ohio
    As you get more experience the pucker factor will go away.......... until you are not expecting it, then it will come back very quickly!
    mark costello-Low speed steel
