Results 1 to 9 of 9
Thread: Warner magnetic brake
    Sep 2008
    UK
    Default Warner magnetic brake
    Warner magnetic brake.TB 1000...has anyone got experience of these things and could tell me how they work? How to set up and how to maintain?
    http://www.warnernet.com/PDF/P-771-WE_pg072-077.pdf
    and some good pics of the magnet on this ebay link
    http://www.ebay.co.uk
    So I am having a bit of trouble with this one...there are things that defy logic.
    Maybe PM me for a talk so as not to bore everyone
    Thanks
    Apr 2010
    Canada
    If you are looking for the brake device, they are fairly simple, one side is connected to the machine frame and the other a rotating disc that attaches to the rotary shaft, a DC voltage is usually used to energize the brake, this clamps the rotating disc to the stationary one for braking, you can get alternative types, one that brakes with power on, the other requires power to remove the brake action.
    The clutches are a very similar principle.
    In many applications you do not need a fancy controller, a simple DC bridge will work.
    The 90vdc shown can be run directly off 120vac with a bridge, although being in the UK your AC off the mains would be 240vac.
    Max.
    Sep 2008
    UK
    Yes, Max, I thought they were fairly simple.
    The bit that I don't get is the rotor and stator run steel to steel, the steel referred to is the ring inside and outside the friction lining.
    So my problem boils down to two questions.
    How to stop this thing squealing?
    How do you know when it needs replaced?
    ....and thank you.
    Apr 2010
    Canada
    I have personally never come across one that runs steel to steel, as the ebay link shows, it is usually a composite material similar to that used in auto brake pads or manual transmission clutches, either asbestos or now more likely some other composite material.
    Max.
    Nov 2009
    Winchendon MA
    When they squeal its time to change the magnet, there is a composite material with the coil embedded along with a plate to make the magnetic attraction that makes it work. By varying the DC voltage is how much braking you get.
    Sep 2008
    UK
    This one is not long new and has most of the lining thickness intact (has a wear indicator hole). Out of the box the magnet was skimmed flat, the steel body being the same level as the friction material.
    Its mating cast iron rotor is also flat.
    I understand the voltage and magnetic and braking power thing. My trouble is the steel rings on the magnet( as seen in the ebay pics) rub in the rotor and wear themselves into the rotor as wear progresses....and want to sqeal as they go.
    Something in me says the friction material should be higher than the steel but that is not the way it is made....
    maybe this is an uncommon version.
    but keep talking, i am out of ideas to make it run quiet.
    Apr 2010
    Canada
    A couple of Warner engineering articles.
    http://www.warnernet.com/PDF/AutoGapFeatures.pdf
    http://www.warner-china.com/DAINCI1.pdf
    Not sure if it will help?
    Max.
    Sep 2008
    UK
    .....reading. Thanks for taking the time.
    the sub-tropical island of Anglesey, North Wales
    Quote Originally Posted by Davidhcnc
    Oil/grease or Ear-muffs
    John
    I used to be indecisive. Now I'm not so sure , but I'm not a complete idiot - some bits are still missing
