Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
Thread: expensive demonstration
    Apr 2004
    52N 122W Western Kanuckistan
    Expensive? Try pricing a conventional ad to run hundreds of thousands of times internationally. Viral Video is the future of advertising.
    Nov 2009
    Ontario
    That was pretty cool!
    I guess there was no point in the operator wearing a hardhat but the commentator should not have been standing under the excavator.
    If you buy crap, be prepared to re-design and fix it.
    Jul 2008
    I've never run a Liebherr hoe, But I can say you can bet that's not a stock off the shelf machine. Standard machines won't do that because there's no need. While digging, If the rear counter weight is overpowered your wasting your time. Compare a normal hoe's hydraulic cylinder arangement. Normally you have a single cylinder on top of the boom to operate the stick, (the part between the main boom and what he uses to get a lock at the very end of the boom stick assembly). You'll also see twin hydraulic cylinders powering that plate. Normally there's one. No doubt all hydraulic lines would be upgraded to at least triple braid, The hydraulic pumps are most likely larger and certainly more powerful, And the engine stepped on to add more horse power. I'd also say I'd bet he has a mini camera to view that plate position so he gets a positive lock. Yeah it's a impressive demonstration, But with that towers design there's little chance of anything going wrong. Their also beating the hell out of those track rollers supporting the full machine weight over a very small area. It's still a pretty cool video though.
    Pete
    Grimsby... 51state of the USA
    That was done for a German TV show called "Wetten Dass"....
    where they bet on wether something can be done...a "You bet" show
    So the exposure was cheap imho.
    Rob
    Jul 2008
    I've seen one other video of that demonstration and it looked like it was done in an indoor sports complex. I think Liebherr fund the whole thing as a traveling show. They do make very good, expensive construction and mining equipment. There's one of a real large Lieberr hydraulic mining shovel crushing a car just by opening the bucket that's full of water somewhere on Youtube. Very impressive IMO.
    Pete
    Canada, Bc
    Nifty, it looks like theres little latch bolts that extend into into the structure from the 'plate', so that looks pertty secure...
    the locking into the tracks those.. that scares the hell outta me!
    Spokane, Wa
    Quote Originally Posted by uncle pete
    Pete
    The fact that the machine is doing what it is doing, is enough to convince me the company knows what they are doing. I think that might be a selling point.
    Gene
    South Wales
    i have seen the thing on a different one, there are fixtures under the machine too, shes not gripping on the track, well it couldend, inadequate friction, might grip a wood pad like ok but that weight steel on steel wont work [ trust me on that i have watched some big steel things sliding this morning cos some numpty forgot the oak blocks!, an im not guilty this time]
    it is an impressive sight though!, if i was the drive id be pissing myself, next they plan to loop the loop for a bet!
    mark
    On the Oil Coast
    I still say one slip and his butt bites a hole in the seat
