Results 1 to 10 of 16
Thread: Mill as lathe programing?
    May 2004
    Vancouver, Wa
    Default Mill as lathe programing?
    I would like to try and turn some 1" 6061 in my mill spindle as a lathe I have 2 diameters I need to turn (a spool type shape) on the end of the shaft. I can't get my mind around how to make the toolpaths. Basically the shaft is 1" and there are 2 slip fit surfaces that are the same diameter I will use .750" as an example in between those 2 surfaces is a clearance area that is turned to .625". The clearance area is the part that stumps me the other surface I could make with a drilling path but I have been trying to figure out how to do the clearance diameter path. My cad does not have a simple solution and neither does my controller at least I have not been able to figure one out.
    I would like to face off the end then turn to the .750" dimension and finish by doing the clearance path down to .625" between the two surfaces that will be .750".
    My Cad will output to a Fanuc 6 code that I need for the mill but I am not sure how to generate this path.
    I can post a picture if this is unclear.
    Thanks Mike
    Beaverton, OR
    If you use cam to create lathe path g-code it should run fine.
    May 2004
    Vancouver, Wa
    Quote Originally Posted by macona
    My Cad/Cam program does not do lathe work it is a program designed for router tables Aspire by Vetric. It is a great program for my router table and will do most things I need for the mill but this is one thing it won't do. My controller will also not do this. So I either need to have someone else make the cut files or buy a new program do you know any reasonable ones?
    Dec 2008
    Kendal, On
    I've done it before. I just programmed in the xz plane. I use edgecam at work, and it has a "slot" cycle, whereas it creates code base on the geometry you draw. Draw the geometry in the zx plane and run a slot cycle on it, and it will move the machine the exact way you want it. Takes a bit of figureing out what to draw to get the machine to cut what you want. But that's the basics of it.
    worked great when I figured it out, and got it working. Just have to think a bit different about what you want to cut and how you need to move the machine to do it.
    Mar 2002
    Kirkland, Washington
    Default What moves
    Is the part spinning or is the cutter spinning?
    If the part is spinning then it will be a series of X and Z moves. This will take a bit of playing around with cutter shape and probably you will need 2 cutters to get the corners cut out.
    If the cutter is spinning you could use something like a keyseat cutter. This would be a series of X and Z cuts as well as some I and J code.
    It is all hand writeable.
    May 2004
    Vancouver, Wa
    I am going to spin the part in the quill and use a tool like this clamped in the vise. http://www.youtube.com/watch?v=-CezQkZwHMA
    I just have to figure out the code.
    Beaverton, OR
    It really should not be too hard to program by hand.
    You might look at Lazyturn. It is being written by Art, the guy who wrote Mach3. I don't know if there has been any recent work on it but you might look into it. There is just not a lot of interest in cnc turning for the home guys.
    Sep 2009
    Spencer MA USA
    I think you can make this work, but the program will need lots of tweaking to get chip control. Understand that the material in the video is 1045 steel, and the groove-turn inserts used are designed for steels. In aluminum the chips are going to get all wrapped up around the work and scratch it all up.
    Aluminum is such a completely different beast. The 6061-T6 (wrought, not cold-finished T651 variant) is about the worst for breaking chips. Your machining life would take a turn for the better if you could find and use 2024-T4 or (better yet) 2011 "Microchip" aluminum.
    Dec 2010
    Finland
    I'm not too familiar with G-code, but here is my idea. 1" bar attached to the spindle and a DNMG bit attached to the vice with the cutting edge at X0 Y0 and cutter shank in X-axis direction with the cutting bit pointing right and Z+0 at the end of the workpiece.
    I'm assuming 1" length for the whole spool, groovestarting 0.25" from the end and being 0.25" long. 6000 RPM (WAG) and a big feedrate.
    S6000
    G40
    ; Outside diameter
    G0 X0.4375 Y0 Z1
    G1 Z-0.996 F100
    G0 X0.55
    G0 Z1
    G0 X0.375
    G1 Z-1 F100
    G1 X0.55 F100
    ; Groove
    G0 Z-0.25
    G1 X0.3125 F100
    G1 Z-0.5 F100
    G0 X0.55
    M30
    I'm too too fond of G-code and trying to think in inches makes my head hurt, not to speak of "turning" stuff with a radius and not diameter readings.
    May 2004
    Vancouver, Wa
    I am not sure this machine takes true G-code it has to be in the form of a Fanuc 6 language. Here is a sample of some that was written using my Cad/Cam program Aspire and saved using the Fanuc 6 post processor that I was told to use.
    :1248
    N20G91G28X0Y0Z0
    N30G40G17G80G49
    N40T1M6
    N50G90G54
    N60G43Z1.0000H1
    N70G0X0.0000Y0.0000S4000M3
    N80G0X0.7500Y0.7850Z0.2000
    N90G1Z-0.4175F30.0
    N100G1X0.7550Y0.7900F100.0
    N110X0.7500Y0.7950
    N120X0.7450Y0.7900
    N130X0.7500Y0.7850
    N140Y0.7350
    N150X0.7580Y0.7356
    N160X0.7662Y0.7374
    N170X0.7743Y0.7406
    N180X0.7820Y0.7452
    N190X0.7889Y0.7511
    N200X0.7948Y0.7580
    N210X0.7994Y0.7657
    N220X0.8026Y0.7738
    N230X0.8044Y0.7820
    N240X0.8050Y0.7900
    N250X0.8045Y0.7972
    N260X0.8030Y0.8047
    N270X0.8004Y0.8121
    N280X0.7966Y0.8192
    N290X0.7917Y0.8259
    N300X0.7859Y0.8317
    N310X0.7792Y0.8366
    N320X0.7721Y0.8404
    N330X0.7647Y0.8430
    N340X0.7572Y0.8445
    This is not the whole code it is just part it was too long to post it all. I am also not sure this code works I am going to try it today. This is a series of bored holes to accept the other end of the shaft we are talking about.
    Here are a couple pictures of what I am trying to accomplish and the shaft is cold finished 6061 T-6.
    These are the mounting shafts for the fillet/rigging tables I make for sport fishing boats the shafts mount in fishing rod holder mounts. There is a hex and a hole that need to be drilled but I understand that part. For the hex I will hold the parts in my indexer chuck mounted vertically. I have made these shafts on my lathe but they are pretty slow going and I want the accuracy of the CNC and speed. By the way my spindle max RPM is 4200. Here are a couple pictures of the tables these shafts hold.
    I am a hobby machinist and self taught so I only learn enough to make the parts I need. When I retire I will take classes to learn this stuff better but working rotating shifts nights and days I can't take classes now. Thanks for any and all help if someone is interested in seeing this through with me I would be willing to pay for your time. I am just trying to figure this out one way or another. The tables are made on my CNC router table and are my own designs. My router table is a 8'x4' Shopbot PRS standard the mill is a new to me Trak DPM 3 with an AGE 3 controller. I am not an expert with the router table but I have learned my way around it pretty good I hope to do the same with this mill.
    Thanks Mike
