Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Drilling A Square Hole, MUST SEE
    Quote Originally Posted by Lew Hartswick
    Has anyone here used one? I have a question. How do you "index"
    the square?
    ...lew...
    Thats a good point. You would have to locate an edge of the cutter in relation to where you want your corners to be or no telling where your corners will end up.
    JL................
    Woodinville, WA
    Was everyone asleep?
    There was a thread on this a month or so back!
    Jun 2006
    Austin, Texas
    Quote Originally Posted by aboard_epsilon
    well hes turning in his grave now that the chinese are selling them.
    That's Dijet -- a Japanese company. Their headquarters is in Osaka.
    Default Square Hole
    I called them and tried to buy one. The person at Dijet told me they are only sold in Japan, not available here.
    Nov 2008
    SF East Bay.
    Look at this video to see how it is done. The cam rides in a form that establishes the path of the cutting edges.
    http://www.youtube.com/watch?v=L5AzbDJ7KYI
    Dan
  6. #16
    Not the Watts method, but a method that is "inside out" from the Watts method. May be better, actually, since no guide is needed at the work.
    The Watts has the shape of drill, but with a rounded corner. No cam, the cam IS the drill, turning in the guide which is the round piece inside the holder in the picture. Guide is harder than the hobs of H###
    Drills a good enough hole for many things, including socket wrench square drives.
    Using it in the lathe
    to make a specialty socket wrench end
  7. #17
    Jul 2011
    40miles north of Pittsburgh
    Turtle Creek was the home of George Westinghouse, at that time. Yeah, that Westinghouse. WABCO, or Westinghouse Air Brake Company. Back when great things were being built in the Steel City of Pittsburgh. I wonder if Mr. Watts worked for George. Keith
  8. #18
    Already covered here:
    http://bbs.homeshopmachinist.net/sho...Hole+Drill-bit
    But yes I want one too
    "To invent you need a good imagination and a pile of junk" Thomas Edison
    Better to have tools you don't need than to need tools you don't have
    73's KB3BFR
  9. #19
    Jul 2003
    Vici, Ok.
    Quote Originally Posted by JoeLee
    It figures that it was invented here and reinvented years later across the pond.
    JL.................
    Used to be anytime this subject came up the guy from Slater tools showed up hawking his wares, but I have not seen an appearance from him in a long time.
    James
  10. #20
    Mar 2008
    East Central Fl.
    Default Watts Drill Manual (online)
    Here is a link to the online manual....
    http://metalworking.com/dropbox/Watts_Bros_manual.pdf
