Results 1 to 10 of 21
Thread: Drilling round stock on center
    Question Drilling round stock on center
    I know this must be a simple operation but for a greenie. Here is my challenge. I need to drill a hole using a #42 drill into the side of round stock and have it centered. Please help.
    Aug 2003
    Southwest Georgia, USA
    What equipment do you have?
    It's best done on a milling machine using an edge finder to find the side of the round stock, then moving one half the diameter of the EF + one half the diameter of the stock. That puts the spindle directly over the center of the stock.
    If that much accuracy isn't needed, you can get or make a drilling jig with a hole centered in a V-groove.
    Oops, that'll put the hole in the top of the round stock, not the side. Sorry about that.
    Nov 2008
    SF East Bay.
    You can use the 'ruler trick'.
    1) Put the work in a vice, positioned under the drill or mill spindle.
    2) Put a sharp pointed rod (like the shaft of a nail) in the chuck.
    3) Place a double edge razor blade over the work, and bring the tip of the rod down on it.
    Move the vise until the blade is horizontal. When the blade is at 90 degrees to the rod, it is close to being perfectly centered. Lock the vise down, replace the rod with a drill and go for it.
    Dan
    Apr 2011
    South Louisiana
    Thumbs up
    Like Winchman said. Touch off on the side of round stock with the side of your drill bit. Move 1/2 your tool plus 1/2 your stock and you will be in the center.
    1/4"=.250/2=.125
    #42=.0935/2=.04675
    .125+.04675=.17175 or rounded .172
    I would use a small center or spot drill to start the hole. You can touch off with anything you want to get to the center. Center is center.
    Define "side" of your round stock.
    Mar 2010
    Chicago, IL
    Quote Originally Posted by H380
    Follow that advice. When drilling into a curved workpiece, your twist drill bit will wander on engagement--guaranteed. A spot drill with an angle at least that of your drill bit is best. Spot drill to roughly the full diameter of the hole you want to drill. Follow with the standard twist drill. I realize this is a fairly small drill bit on a fairly small workpiece, so I will mention the other option is to use a drill bushing to guide your drill bit into the workpiece. Here is a nice little primer: http://tinyurl.com/6s4buz7
    Jul 2009
    SF bay area, CA
    Quote Originally Posted by winchman
    Rather, I think it would be more accurate to edge find BOTH vise jaws and then move to the middle.
    Albuquerque
    And if youre holding it with two [Matched] V blocks use the inside
    edges of the V blocks to edge find on and divide by two for the centre.
    ...lew...
    May 2007
    Live Oak, TEXAS
    If the hole doesn't need to be "EXACTLY" on center, (say within .005-.010), then use one of these: They work great for a quick & dirty center-find on any round stock.
    $5.00 at any online supply.
    If the hole needs to be 'EXACTLY" on center (within +/- .002), then edge-find the back vise jaw, and move over 1/2 the work diameter.
    As said before, use a spot drill or center drill first, to guide your drill.
    Mar 2010
    Winnipeg Manitoba
    Theoretically, crotch center in tailstock, bit/chuck other end (collet held, 3/32" or so?), wouldn't vouch for accuracy though...self-centering vice mill or drill press...depends on equipment and accuracy needs
    Aug 2008
    Kansas
    Quote Originally Posted by KiddZimaHater
    You know, I never knew such a tool existed, but now that I do, I need one!
