Hi folks,
My mill came with a 3 phase motor which the sales guy advised me was dual voltage 440/220. I'm in the UK and have single phase 240v supply. I have been using the mill for about a week now with a VFD which converts my 240v 1ph to 240v 3ph.
It seems to run fine but I'm not sure if the wiring is right or not. There was no wiring diagram to show how low voltage should be set, and it doesn't mention low voltage on the name plate.
I've attached a pic below, please could someone advise me if this is right, or should I be altering the links to Delta configuration? The name plate seems to indicate that it's wired for 415v at the moment so it seems odd that it'd be the same for 240v, but it does seem to be working fully, and I don't suspect it's at half power (but maybe I'm wrong!).
By the way - my wires which are labeled U/V/W are connected to the corresponding U/V/W terminals, just the terminals opposite don't line up, so if it looks like I've connected V to U and W to V then don't worry, I haven't
