Results 1 to 8 of 8
Thread: O3A3 action thread
    Jun 2010
    Crawfordville, FL
    Default O3A3 action thread
    I've got an O3A3 action coming from Navy Arms. No barrel. I've heard these actions have true "square" threads, not acme. Anybody got any information about these things? If I've got enough meat, I may well chase the threads to standard 60 degree. Thoughts? Anybody know the dimensions for the cutter to cut true square? Seems something fundamentally wrong with square. Either the male or the female MUST have some relief cut in...
    1smalljohnson
    If no one comes up with it before, I can get the info you need tomorrow.
    I have an old barrel at the shop that I can get the TPI and min.max.from.
    For what its worth,the kraig,1903,and m1,all used the same thread.I do not know about the m14.
    Feb 2008
    Arizona
    The barrel shank is .734" long, With a body Dia of .990 A thread Dia of 1.040".
    The threads are square with a pitch of 10 threads per inch.
    Nov 2003
    Rolland has it right. I ground a tool very similar to a cuttoff tool, .052" wide which gives a bit of clearance. I found it tends to curl a bit on the edges while cutting the threads, so I just used a flat file to keep things smooth as I went.
    Aug 2008
    Missouri, USA
    Here is the receiver thread should you need it.
    1903 receiver drawings
    Sep 2011
    Belgium
    Quote Originally Posted by Highpower
    That is very interesting. Thank you. What is the source book, please?
    Montezuma, IA
    Is this an original receiver? You'll need a drawing of the barrel shank, since there is a cut for the extractor in the barrel as well as a feed cone cut in the breech.
    David
    David Kaiser
    Montezuma, IA
    Jun 2011
    bbl shank in front of receiver 1.145
    shank length .734
    bbl shank where threads are 1.040
    outside diameter cone on breech .990
    angle of cone on breech face of barrel 41 degrees
    thread ten square threads 10 sq tpi
    source of information "bolt action rifles by Frank de Haas revised edition
    Hope this helps, Frank
