Results 1 to 10 of 16
Thread: Question Re: "V" belts:
    north bay area
    Default Question Re: "V" belts:
    I have an older single cylinder compressor i picked up and have pretty well restored it.
    It runs quite good, but can someone tell me WHY i cannot get the "Flutter" out of the "v" belt when it is running?
    The "Flutter" is mostly on the bottom of the belt which would be the return side from the motor to the compressor pulley.
    Pulleys are lined up as perfect as i can get them in three trys, Belt tension is as it should be, (This is a new belt,) Is it the single cylinder "Pulse" from the compressor that is causing this or??
    Any ideas on how i can eliminate the flutter, i just find it annoying?
    Thanks.
    Canada, Bc
    More belt tension.
    You think thats annoying, My multi ribed belt squeaks like crazy untill the belt 'jumps' one rib
    Then it works fine.... So uhh, I leave it with one rib 'jumped' out of the grooves. Im sure its really just an alignment problem but its SUCH a pain to get at those motor/compressor bolts I just can't be bothered.
    Bremerton Washington
    Use V belts with a notched inner profile; the secvtion designation has an "X" - "AX' , BX" etc. These are more flexible and efficient than the standard ones.
    Some prefer the linked V-belts where the belt section is composed of stamps short links that hen connected forms a V section. They are expensive but very smooth running and effective. They have the advantage of being "connectable" through openings so spindle don't have to be dissassembled to install a new belt. They are not as effective in transmitting power for small pulleys as the notched inner belts.
    So if one had needed to replace the belt on his turret mill, an AX would be the better choice because of the very small first position on the motor's step pulley than a linked belt. I need to do that but have been dodging the task for several years. Hey! It still runs on bottom speed so long as I don't load it to slippage. Whatta a lazy butt I am.
    Default V-Belt
    You could just put an idler wheel under the belt, maybe even a spring tensioned one. That would be better than overtightening, which would cause excessive wear on the bearings and belt.
    Nov 2008
    SF East Bay.
    Just a guess, but the load of a compressor is very erratic. The power required goes from very high to little or nothing and back again quickly. If the valves are letting some air back into the cylinder it may even be turning the pulley at some part of the up stroke.
    I think that will cause the flutter as the belt becomes loaded and unloaded.
    Dan
    Chilliwack, B.C.
    Something I've done to combat that is to mount a piece of flat metal so it's parallel to, but not quite touching, the loose side of the belt. When the belt begins to vibrate it will start slapping against this metal piece which will dampen the vibration. The amount of time the belt rubs the metal is quite low, so there's no significant drag induced or wear on the belt.
    In the unlikely event that the natural period of vibration of the attachment matches that of the belt, it could make the problem worse. You'd just have to change the size of it, or possibly add some damping felt to it.
    The things you'd play with is the spacing between the attachment and the belt, and the position of the attachment between the motor pulley and the compressor pulley.
    north bay area
    Re: The suggestion of an idler pulley:
    Possibly,, i did hold a wooden hammer handle up against the bottom belt and it seemed to take the flutter away nicely.
    Belt tension did not change it much at all, i have the belt snugged up to 1/2 inch of deflection in ?? 10 inches.
    Nov 2010
    Lafayette Indiana
    There is always going to be "flutter" due to one side of the belt being in tension and one not during operation. Any time you add an erratic load (your compressor), it only makes it worse. As stated above, there are various methods of solving it. Personally I would NOT crank up the tension, but rather do as darryl suggested with something flat almost, but not quite touching the belt.
    52N 122W Western Kanuckistan
    Very likely the resonant frequency of the belt is near the stroke rate of the compressor. Changing tension will change that some but changing belt length will change it a lot (much harder to do). Changing the weight of the belt will also make a difference.
    north bay area
    Pulley sizes are 3 1/2in dia. on the motor and 10 inch on the compressor.
    1725 motor.
    Pulley's were lined up with a steel straight edge.
