Results 1 to 5 of 5
Thread: Cast iron & steel connection - filler?
    Aug 2008
    Missouri, USA
    Default Cast iron & steel connection - filler?
    Recommended filler to use for attaching heavy wall steel pipe to a grey cast iron plate?
    Sep 2008
    Ni55 rod. The MUCH more expensive Ni99 rod does not make a stronger weld contrary to popular belief, it does however make a softer weld that can be machined if necessary and that's it's purpose.
    Aug 2008
    Missouri, USA
    Actually I should have mentioned that the end of the pipe will sit down inside a shallow counter bore in the cast iron piece. In order to keep the heat down on the CI, I was thinking of maybe tig brazing it with silicon bronze?
    The pipe will actually be bolted on from the rear of the CI, but I would like to reinforce the pipe at the front (counter bore) for good measure. I just don't want to run the risk of cracking the cast iron.
    May 2009
    Minneapolis, MN
    JB weld is what I'd do then.
    Sep 2008
    Quote Originally Posted by Highpower
    Yes of course that's the best way to do it, don't know why I just assumed you meant arc welding. The worst part of my suggestion is that most of the time when someone asks about joining iron castings I tend to discourage arc welding and only do it myself when brazing is not practical for some reason.
