Hi guys. I've been working on a design for awhile now, and have most of the details down at this point, but am running into one problem. Part of this project uses 2 rectangular blocks of material about 4" x 2 1/2" x 1 1/4". I would like these to be wear resistant, needs to be machinable (conventional methods), and also need to be dense. A heavier weight to size is preferrable. I have looked at using tungsten carbide, but the blocks will need blind tapped holes and some contours which dictate EDM work (wire and sinker). I think this will blow my budget (I'm borderlined right now, on paper at least). I've also looked at tungsten steel (NoChat), but apparently it can only be had up to a hardness of 30 R/C. Is there a material which can be milled, has the mass of carbide and can be heat-treated to around 56-60 R/C? Or is this the dreaded "Unobtainium?"I've also thought about "slugging" blocks of D2 (or the like) with carbide round, but I think that would be a last ditch effort. Any ideas? Thanks in advance for any help.
