Originally Posted by
Toolguy
I would use a small diam. boring bar. Drill a hole a little under 9mm. Set the compound to cut the taper. Bore the straight part using the carriage as normal and stop at the depth where the taper starts. Then wind the compound slide to the bottom of the hole and you're done! You will have a perfect transition from the straight to the taper. Do rough and finish cuts, not all at once.
x2. Use a carriage mic stop to get a uniform depth on the straight portion, then simply use the compound to cut the taper.
