Results 1 to 10 of 10
Thread: Drill/mill, the tool NOT the machine plus noob mill question
    Mar 2010
    Winnipeg Manitoba
    Question Drill/mill, the tool NOT the machine plus noob mill question
    Drill/mill tool, is the idea sort of to reduce number of processes?
    Can you mill with the drill portion?
    I am still working towards setting up an Atlas horizontal mill so am used to thinking "horizontal arbor" but there would also be application for holding other types of mills both in the spindle of that mill (MT#2) and the lathe spindle. I've come across what could be a good deal on a Morse drill-mill and its of a size, 3/4", that with the 90* drill angle, it should work for me to make various stops for the lathe (I would not need to go full depth to match the prismatic ways).
    Part 2 springs from that and another deal, same guy selling. Do end mills cut on the "sides", ends, or both?
    I assume "center cut" means they cut across the full width of the end of the cutter.
    Reason: center cut mill has chips in a couple of spots on the flute edges going towards the top but the end edges are near perfect [if I only use the end to cut the intent would be to regrind past those chips when it would become necessary...its a high $$$ mill]
    Dec 2006
    Hazel Park, Michigan
    A quick google search will reveal the difference between center and non-center cutting end mills......
    http://www.google.com/search?q=cente...BIOmgwf5ntScCA
    The very first picture is a good example.
    A center cutting mill will allow you to plunge in. The other will only allow you to go so far before it bottoms out.
    End mills cut on both the end and the sides.
    Drill/mills I only use as chamfering tools, I am sure others use them differently...
    Nov 2008
    SF East Bay.
    Deleted. I had misread the title, or the title has been updated. Either way, my comment no longer applies.
    Dan
    Canada, Bc
    If you are talking about drills with 'teeth' on the side, Im pertty sure those are more for cutting drywall then milling steel!
    <edit>
    Default Mill Drill
    A mill drill (the cutting tool, not the machine) will drill, spot drill, side mill, chamfer, v groove and countersink. It is an endmill with a 90 degree drill point. They are a very handy item. They come in sizes from 1/8 to 3/4, 2 and 4 flute.
    An end mill will cut on the end and sides. A center cutting end mill will cut to the center, a non center cutting end mill often has a countersink in the middle. The cutting teeth only go partway to the center.
    Jun 2006
    Austin, Texas
    Quote Originally Posted by Toolguy
    +1 -- I love the mill/drill bits. I get them in carbide, and they make super rigid spotting/center drills. Yes, you can mill on the sides.
    Canada, Bc
    Can you find a picture of these bits to post?
    Mar 2010
    Winnipeg Manitoba
    Sure, out of catalog, middle two sections
    http://www.kbctools.com/can/Navigati...fm?PDFPage=203
    those are solid carbide...Toolguy posted a very good description.
    Knew they existed but was not quite sure if they were multi purpose or not.
    Until I get a vertical mill, and being a noob, I am sort of creating work-arounds for projects. As example, to obtain a "V" groove to match the prismatic ways on the lathe (so as to build a few stops etc.) I need a cutter that will produce a V groove about .625 at the widest. Most suppliers have horizontal arbour cutters that will do this but there is a price jump over the 1/2" width. This drill mill would solve that, plus its at hand and a good deal (though HSS, it is from a good maker).
    Oct 2005
    British Columbia
    Quote Originally Posted by Black_Moons
    Home
    Good judgment comes from experience, and experience....well that comes from poor judgment.
    Canada, Bc
    Shiny.. Now I want one. -_-
